Pics of Progress
Old Jun 17, 2003 | 09:39 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
Pics of Progress
This is how far i am and i'm still waiting for my FAST ECM. Too bad not gonna make it for nationals but i guess it'll be worth the wait.
Old Jun 17, 2003 | 09:40 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
Old Jun 17, 2003 | 09:46 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Sweet...let's hope some of your new engine carma rubbed off on the Griffin and the Edelbrock WP
BTW...check your email...Thanks.
Old Jun 17, 2003 | 11:30 PM
ericoo1's Avatar
Car: 89 silverado,02 s10 blazer
I hope you get your FAST setup quicker than I got mine. I got the sequential w/ wideband pre wired for MSD ignition and it took almost 3 months to get mine. I just thought I'd inform you, maybe I just ordered mine at the same time the rest of the country did
Old Jun 17, 2003 | 11:41 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
wow three months, i hope i don't have to wait three months, i'll have classes in three months and i need this boy to get me there.
Old Jun 17, 2003 | 11:44 PM
ericoo1's Avatar
how much did you pay for your's? I'v enever sen any prices anywhere other than where I got mine.
Old Jun 18, 2003 | 12:02 AM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
I paid $1949 with the Wideband option at www.jimsperformance.com , hes knows his stuff and local to me so thats why i picked it up from him. I didn't opt for the sequential port option as it was alot more work for little gain in my case.
Old Jun 18, 2003 | 09:06 AM
MdFormula350's Avatar
darn man that's looking great. :hail:
Old Jun 18, 2003 | 03:40 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
holy fark! is that $2k for an ecm?!
Old Jun 18, 2003 | 07:24 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
yeah
Old Jun 18, 2003 | 08:26 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
To think a 730/749 and a 730 memcal would have cost you a $100.
Common as fleas, so a replacment is easy to find..
A diy WBO2 and sensor would be another $250..
However thats just my opinion... Nice set up..
BW
Old Jun 19, 2003 | 12:51 AM
bigals87z28's Avatar
Car: Check The Sig
aside from the 2k on the ecm... THATS A FRICKIN 388 WITHA SUPERCHARGER!!! oh mommy that and the 406 Turbo... ooo sweet mother of ***!
Old Jun 19, 2003 | 07:10 AM
Spdfrk1990's Avatar
what yr is that block can u use a older block and still bolt up everything like the smog pump??
Old Jun 19, 2003 | 08:16 AM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
the block is a late 70s 350 4 bolt out of a truck. Everything bolts up to fine.
Old Jun 19, 2003 | 08:31 AM
Spdfrk1990's Avatar
Thats awsome i have a 76 350 4 bolt block from a truck i didnt know if it would have some of the sensors holes needed. Also i like the TPI look would a 383 be fine with the tpi setup.Will the smog pump bracket bolt up fine also i dunno if i want to delete the emissions or not.
Old Jun 19, 2003 | 10:32 AM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
you will need to drill a hole and tap for the oil pressure sensor, thats the only problem i had. The smog pump bracket bolted up fine with my sepertine setup. I like to use stuts for the lower two holes on the block for the passenger side bracket. As far as having a tpi, that should be fine as long as you don't have a wild cam or anything. TPI will limit the upper rpm power if you thats what you're lookin for. You can pass emissions without the smog pump, that is considering i did with my bone stock 305 years ago.
Old Jun 19, 2003 | 10:45 AM
Car: Check The Sig
ahhhh tpi on a 383 motor? if you can, look into getting a HSR. you can pick one up for like 500 and you can reuse some of the tpi stuff. 383's like to build up torque and tpi will help it down low but as you go higher tpi will choke it off. 383 is a deep breather and tpi wont give it the right air if you have a soild set up. Try porting the chit out of what you got to free up the bottle neck... the plenum can be done easily, maybe aftermarket runners, and port the base. If you are really set on tpi and dont want to go to a different setup, then get a high flow base and gut that thing too. the tpis, edelbrock, and accel bases have extra meat so that you can really open up that base. Also SLP, Edel, or AS&M make good runners.. as for the plenum... break out the dremmel baby!!
Old Jun 19, 2003 | 11:48 AM
Spdfrk1990's Avatar
(I like to use stuts for the lower two holes on the block for the passenger side bracket.) What do u mean by that derfrank i think u might of miss typed but just checkin what u said. Also i talked to a guy at jims performance in md he said it would be ok to go with a pretty healthy cam like around a 519 lift since i have a 5 speed. Yeh he also said with the 383 the tpi will choke off the top end but he said it will still be a torque monster.
Old Jun 19, 2003 | 01:02 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
i think i meant to say studs, here is a pic so you can see what i'm talkin about. Is your car already tpi? If not, i'd go with a Holley Stealth Ram because for performance for dollar value. If you wanna spend some money, the Miniram is the nicest i think because of its low profile look and ability to pass it off as a LT1 to the people who don't know. If you don't have AC and wanna convert to TPI and your car is a 90, i have a harness that you might be interested in, PM about it if you need something like it. If you want the thing at barely emissions legal, i'd go with the comp cams 224/230 cam for max power and be able to pass smog testing. It took me a while to get my 222/230 legal but with tuning i got it through. So if you're not good with chip tuning or haven't even thought about it, i don't suggest that cam. Go with something smaller like the lingenfelter 219 cam which is still a nice size cam for the street. Also, don't expect the stock 5sp to handle too much power, but we'll leave you to asking the question abou that on the tranny board.
Old Jun 19, 2003 | 01:03 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
heres the stud photo
Old Jun 19, 2003 | 01:05 PM
David 91RS/Z28's Avatar
Alex....how did you overcome the longtube collector hitting the t56 bell housing problem? I probably missed the post, so I was just curious.
BTW, very nice setup you have going.
Old Jun 19, 2003 | 01:09 PM
90_formula_305's Avatar
nice work
Looks good here a pic for some ideas.
Old Jun 19, 2003 | 01:13 PM
Spdfrk1990's Avatar
ok did u have to drill the block or the bracket for that
Old Jun 19, 2003 | 01:21 PM
don't really know. It's not mine. I took the picture during a car show in daytona. It from the turkey rod run. I could ask around town next time I see someone with this set-up.
Old Jun 19, 2003 | 01:24 PM
if i rember correctly the turbos were mounted to the engine bay and then piped-in
Old Jun 19, 2003 | 01:26 PM
another angle
this angle may be helpful
Old Jun 19, 2003 | 01:45 PM
Spdfrk1990's Avatar
how much r holley stealth rams
Old Jun 19, 2003 | 01:53 PM
Car: Check The Sig
500 from thunder racing i belive... just reuse your old tpi stuff and you should be fine... anyone can chime in to tell me if im wrong or not..
Old Jun 19, 2003 | 01:55 PM
Spdfrk1990's Avatar
you cant use your fuel rail can u
Old Jun 19, 2003 | 02:03 PM
Spdfrk1990's Avatar
wait i justed checked it out i see the fuel rail i could of bought that instead of buyin this tpi intake hmm i dunno.
Car: Check The Sig
or some strange reason i think you can, but the lines are different
Old Jun 19, 2003 | 03:31 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
I'm not sure, i bolted up new urethane mounts and changed the k-member to a tubular one. Not sure but my header has like 2 inchs of clearance by the bell housing on driver and passenger side.
Old Jun 19, 2003 | 05:09 PM
OK. That has nothing to do with the way the headers bolt on, but I'm glad it worked out for you. Good luck with the car.
Old Jun 19, 2003 | 05:39 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
Ok i went outside and looked and its more like 1.5" on the passenger side and the driver side is real close with only about 3/4" of space between flange and tranny.
Old Jun 19, 2003 | 06:06 PM
The last thing I remember was one of the header collectors was interfering with the bellhousing or something. It was in one of your posts quite sometime ago. No biggie....I'm glad it fit without having to modify it.
Old Jun 19, 2003 | 06:12 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
ahhhhhh yes, 1991-Z28 had that problem, hes a good friend of mine and supposely he had that problem according to thirdgen resource who did the work on his car. I haven't even looked under the car to see how and what they cut on his car.
Old Jun 19, 2003 | 06:13 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
when i get a chance, i'll take some photos from under neath the car so you can see the clearance on it.
Old Jul 16, 2003 | 11:10 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
the badboy should be up and running some time soon, expected firing up date is less than 2 weeks.
Old Jul 18, 2003 | 05:07 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
sweet
Old Jul 18, 2003 | 05:28 PM
Spdfrk1990's Avatar
defrank i was thinkin of havin my prom burned and my harness change over from tbi to tpi done by jims performance. I talked to him a few times seems like he does really know his stuff and a super nice guy. Would u recamend them for the prom burning and the harness change over.I think im gonna save up also for the mini ram.
Old Jul 18, 2003 | 07:44 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
I highly recommend jims performance for the harness deal. If hes willing to do the prom for you, i would shoot for it. Me and him both agree that it is still best for you to burn the prom yourself as he doesn't have the car infront of him to actually do testing. Yes, do save up for the miniram. Its worth it in every bit.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Lanz06
Mar 13, 2019 06:07 PM
86IROC112
Oct 9, 2015 10:38 PM
gt4373
Sep 9, 2015 10:29 AM
