got 3500$ saved..what to do!?
Old Jun 18, 2003 | 02:36 AM
Tater13150's Avatar
Well i got 3500 saved up, now i dont know where to begin..i already have headers and free mods and some bolt ons..the engine has 55k miles on it..should i go with a 383 tpi setup or would i be better of with heads, cam , intake 350.... what to do what to do!!
Old Jun 18, 2003 | 06:06 AM
Wootah's Avatar
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
that would make a nice chunk of change for an LT1/t56 swap
Old Jun 18, 2003 | 03:34 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
procharger.
Old Jun 18, 2003 | 04:53 PM
smithtc's Avatar
What car, gears, rearend, transmission, suspension setup?
Plan on autocross, road race, street race, drag race?
I would keep the 350.
Buy heads, cam, intake, torque converter, and gears to match...
Heads: $750-1500
cam: $100-300
Intake: $400-1200
Converter: $200-650
Gears: $150-500
If you go all cheap for the $1600...you'll have room for the 383 short block, especially if you do a lot of the work, or suspension mods like torque arm, lower control arm relocation brackets, SFCs, etc...and nitrous.
Could also figure out what your goal is while the $3500 sits in a CD as well.
My $0.02
Old Jun 18, 2003 | 06:22 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Originally posted by N8MAN1068
procharger.
I second that!!!
Or you could give me the money so I can get a Procharger!!!
Old Jun 18, 2003 | 08:56 PM
Tater13150's Avatar
Well i have a NX kit on the car already, the suspension is stock, and i have a 2600 converter. I'll be drag racin it. Would a lt-1/t-56 swap be worth it..how bout a ls-1 swap!?
Old Jun 19, 2003 | 05:03 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Since you mentioned a stock suspension you may want to hit that area. I bet doing the entire rear and refreshing the front won't cost all of your savings...
Old Jun 20, 2003 | 07:13 AM
Error404's Avatar
Car: 86 Iroc
Engine: 350 crate
Transmission: built 700r4
I wouldn't just slap a supercharger on there, or some Juice, I'd take smithtc's suggestion and build up the engine it self. then if you still want more, plop a supercharger on it or what not
Old Jun 20, 2003 | 06:49 PM
90FormulaWS6's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
if your gonna be drag racing you better get your suspension ready for it... do your entire suspension lca,panhard,springs,sway bars, then hit up the engine, and slicks
Old Jun 20, 2003 | 07:25 PM
FactoryFreak's Avatar
Car: 1988 GTA
Transmission: TH350
Spend about $800 in the suspension, torque arm, lower control arms, relocation brackets, panhard, subframe connectors (very important). Get some 3.73's in the rear, mount some slicks, that should cost around $600-$700. Some AFR Heads and a Comp Cam. Sould probably cost around $1800-$2000 for heads and cam. That should easily get you low 12's if not 11's with the NX kit.
Old Jun 20, 2003 | 07:29 PM
jeffsbluez's Avatar
Car: 91 z28
BUY THE PROCHARGER!!!!!! You will be soooooo happy
Old Jun 22, 2003 | 10:02 PM
T/A gets T&A's Avatar
The procharger would be cool, but what good would the power increase be if you can't put it to the ground? I'm thinking you'd be much better off with suspension upgrades before the charger. Spohn stuff is great.
Old Jun 23, 2003 | 12:46 AM
Morley's Avatar
Don't ignore the transmission and differential. If you start building up the engine for power and run slicks (even drag radials) You're going to have a disaster. Either the diff or trans is going to let go, the factory installs wern't meant for that kind of power/abuse.
It is all a balancing act, First get the suspension up to par, then the trans & diff, THEN you can put some real power out in front.
If you blow all your money on the engine and the trans "explodes", you're going to be SOL.
Old Jun 23, 2003 | 08:34 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Everyone makes good points and I agree completely that the whole car needs to be setup for whatever kinda of application(abuse!!) it will be used for. However, if it were me, I would get the 'Charger now cause ya got da cash and upgrade the other stuff as I went. Keeping in mind the limitations of the factory hardware and components a supercharger SHOULD NOT destroy or damage a car while a heavy foot with less than adaquete parts will leave you waiting for the bus...
You can do tranny and suspension work cheaper than the cost of admission into the supercharger world. Just my thoughts. For all I know you don't even want a supercharger...
Old Jun 23, 2003 | 09:13 PM
smithtc's Avatar
He's already got nitrous.
Old Jun 23, 2003 | 11:08 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Yeah, supercharged nitrous, thats the way to go!!!! THats where the powers at!!!!
Old Jun 24, 2003 | 07:07 AM
smithtc's Avatar
$2500-3500 for the supercharger.
~500 for a junkyard engine once his breaks into many pieces.
That, plus the potential fried trans or rear. Sometimes people just need to use common sense. One furious blast down the track isn't worth $3500...if it makes it that far. Better have your d.s. loop on too. It's fun to say supercharger, and that would be nice...if you can make everything else around it stay together.
Old Jun 24, 2003 | 07:27 AM
daxfas26's Avatar
Car: cobalt ss/sc, 91 z28, 92 z28
Engine: 385 stroker
Axle/Gears: stock 10 bolt 3.73
i d do what factory freak said get some for suspension and heads and cam. that would be the better road traveled. after u get the heads and cam... think how much more power your car will make with supercharger after those things done. dont forget the tranny too.
Old Jun 24, 2003 | 07:43 AM
bigals87z28's Avatar
Car: Check The Sig
suspension man... build up the car to take the hit of a nitrous and a blower ok. if your gunna wheel hop and spin all the way past the 1/8, and run a 16.4 whats the point of a super charger huh? The answer to your question is right ontop of this page.. Sphon performance. the 350 will be good. do some free mods and you should be happy. also make sure your car is in top shape. Check timming, tps, O2, IAC, MAF/MAP, everything!.. plugs, wires, coil, compression. then do the free mods with the suspension and exhaust. I didnt see anyone sugest exhaust at all here? 1 5/8 headers with a hi flow cat (if your state requires one) and a decent cat back(hooker ) will get you in the right direction not to mention that evil sound!! Then what you have left, look into getting a cam and some heads. Also if you dont have any, get some tools cause you cant work on your car if you dont got at least a decent set of tools. Then after your car is stiff, exhaust is set, heads and cam give ya a neck snapping good time, THEN get a supercharger.. but make sure the rods, pistons, and crank are set for the force. Also a rebuild of the 350 would be a good idea..take it out to a 355, throw some forged stuff in there and you will be able to run boost till the rod bolts snap! good luck with the car.
Chevykid810
Sep 28, 2015 12:57 PM
tuningnewb
Sep 23, 2015 07:06 PM
ULTM8Z
Sep 16, 2015 09:15 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
Dialed_In
Aug 20, 2015 01:45 PM
