do u have to change the chip to change a 350 tpi to a 383 tpi?
Old Jun 20, 2003 | 01:03 AM
Bajram's Avatar
Car: 91 z28 1le
Engine: 357
Transmission: 96 - 6 spd
do u have to change to chip or anyhting like the for a 350 to 383 i know u have to change the crank but is the anything else with the tune port?
Old Jun 20, 2003 | 05:20 PM
FactoryFreak's Avatar
Car: 1988 GTA
Transmission: TH350
Changing the chip with do a lot for hp gains over the stock chip.
Would probably be in your best interest to change it.
Old Jun 20, 2003 | 08:09 PM
KYL98's Avatar
Car: 1991 Z28
Yes, you will definitely have to change it to expect any significant gains......Youre gaining 33ci, and your ECM still thinks there is only 350ci. Post this message over on the DIY-PROM board.....they'll send you in the right direction.....good luck.
Old Jun 20, 2003 | 11:10 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
will it help?
Yes
Is it neccassary?
No... you can raise the fuel pressue with an AFPR and should be able to get near your potentionial
http://www.gmtips.com/3rd-degree/dox/tips/afpr/afpr.htm
BUT, tell us some more stuff, what year is your car, what heads, intake, etc. You may be beyond getting by without custom PROM tuning. No matter your setup with a 383 a custom chip will help.
Frozer!!!
Jan 19, 2024 04:55 PM
NBrehm
Aug 25, 2015 11:49 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
