Pro's / Con's of HSR
Car: '87 IROC
Transmission: TH700R4
What would the advantages or disadvantages of the HSR be over the Mini-ram?
Is the mini-ram a better choice for high rpm use because of the shorter runners or does the HSR have the best of both worlds in regards to street/strip performance.
tj
tj
Car: 1988 GTA
Transmission: TH350
Cost is an advantage since the HSR cost around $1000 less, and a disadvantage would be its not street legal. But if your not in an emissions state the HSR is the way to go.
Car: 92 Camaro RS
Engine: 355 94 p/u motor
Transmission: 700R4 With TCI kit
Anyone who wants to know about HSR....
Check out this link. It says it all.
http://www.gmhightechperformance.com...holleystealth/
I'm definitely gonna get one of those, how can you say....SWEET!!!
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Which would be the best intake for this setup? Torquer 305 heads, CompCam (114LSA, 218/224, .464/.470). This is for the car in my sig. I was thinking about the LT1 intake but it seems like a lot of modifing of the intake has to be done. What do you guys think?
Car: 87 IROC-Z
Engine: 383 HSR $8D
Originally posted by tpi_roc
Some GM sponsored magazine needs to write up a "Performance" review for the LT1 intake
I 'believe' it is out now on newstands.
I know lots of folks that like the LT1...but I don't really like it as I do not like the remote thermostat.
I am sticking with my HSR.
Car: 92 Z28
Engine: Boosted LSX
http://www.popularhotrodding.com/toc/
Scanned and Hosted Here...
http://lt1intake.com/PHR2003AUG.htm
You know if you "Do a Search" you might have found that.
J/K bud.
Car: 87 IROC-Z
Engine: 383 HSR $8D
Originally posted by TPl383
Popular Hot Rod. August 2003
J/K bud.
J/K bud.
Car: 92 Z28
Engine: Boosted LSX
Originally posted by gsf-87IROC
Why should I do the work...I wasn't the one asking the questiont.
I didnt quote you either Did I? I quoted Justin
Car: 92 Z28
Engine: Boosted LSX
I plead "early morning caffeine deficiency" as my excuse.
Sorry.
Sorry.
It doesnt seem that there is actually alot of actuall street abuse results for either intake out yet. There is not an abundance of dyno charts or track slips floating around for either intake. I think its really a bit early in the game to say that one is better then the other, and at what rpm range that might be. This is of course discounting what 4th gens do with the LT1 intake.
I always kinda thought that the LT1 intake looked a bit different in the 4th gens but I think it looks totally out of place in a 3rd gen, i personally dont like the whole remote mount t-stat thing mostly. Sure everything is fully functional but it is probablly something I would bever run, but who knows, its damn cheap, I have 900$ in my Superram parts, and countless hours of porting dammit!!! Thats damn near double an LT1 swap in price, plus all my time.
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
TPI383, Popular Hot Rodding is not a GM sponsered magazine. That write-up on the lt-1 intake is awesome though and it's probably the best coverage you'll get of the intake in any mag.
Car: 92 Z28
Engine: Boosted LSX
Originally posted by camarojoe
I doubt they will ever do an lt-1 swap article, because there's no "company" to profit from that manufactures them.
http://www.lt1intake.com/Granted he is doing it on the Side I wouldnt say he wouldnt profit from the ad in PHR now... Anybody who never knew it could be done and reads the artice will goto the site if they have internet access.
GM sponcered or not atleast its in a Mag. who cares what Mag.
http://www.eecis.udel.edu/~davis/z28...age021105.html
well tested custom plenum slightly over 1" lower than the standard holley plenum for extra hood clearance on c-4 corvettes
http://fasterdeals.com/vette/index.html
standard holley steath ram
http://www.thunderracing.com/index.c...yid=1125#P2944
summit also lists the standard heigh plenum and runners WITHOUT the fuel rail KIT and fuel pressure regulator for $299
the part number for the HOLLEY ADJUSTABLE PRESSURE REGULATOR FUEL RAIL KIT IS 534-186, summit charges $215.39 for that adjustable regulator fuel rail kit
keep in mind that while an adjustable fuel pressure regulator is a nice tuning aid, the non-adjustable is set at about 43 psi pressure
http://store.summitracing.com/defaul...-7540&x=24&y=9
call summit, tech support for details,or better yet HOLLEY tech support................(270) 781-9741
they wrote the advertizing copy.... incorrectly, you will require fuel rail kit # 534185 that costs $ 173.69 additional from summit the stock chevy fuel rails and fuel pressure regulator will not fit, the HOLLEY STEALTH RAM and keep firmly in mind the standard plenum will not fit under the stock corvette hood. If you look closely at the upper right corner picture in that catalog on page 33 of the complete stealth ram youll notice the fuel rails are totally differant than the stock chevy fuel rails and FYI, the picture even has them installed swapped end for end in the catalog, the correctly set up fuel feed starts on the pass side rear and the bye-pass line hooks to the drivers side across the front under the throttle body then feeds down the drivers side fuel rail to the rear, the cross-over line is properly mounted on the front between the fuel rails, not as its shown in the catalog.
,look closely DAVID ALLEN from
http://diabolicalperformance.com/
HAS IT CORRECTLY MOUNTED WITH THE CORRECT FUEL RAILS
NOTICE IN THIS PICTURE THE FUEL PRESSURE REGULATOR IS AT THE CORRECT LOCATION, (DRIVERS SIDE REAR) on this custom stealth ram for daves corvette
86CamaroDan
Sep 29, 2015 10:08 PM
