A few TPI question
Old Jun 21, 2003 | 07:39 PM
Tranny Man's Avatar
A few TPI question
I'm gonna start by saying I SCREWED UP!!!! I thought that by buying a tpi system bit by bit it would be cheaper!! Now I have a 85 tpi upper and lower plenum, a set of runners, throttle body,fuel rail and a complete set of 305 injectors and sensors. The distributor is a HEI coil in cap with out the vac advance with a flat connector. And a pretty nice harness with a few wires cut and a few missing plugs (like the manifold air temp I cant find ANYTHING to plug in there) I also have the ECM and a bunch of relays the MAF and the boot between the TB and the MAF. I also have a stripped 88 TBI car that I'm planning on using as an autocross lapping days car. I NEED a harness that is a stand alone system as there is NO wiring in this chassis. can anybody point me in the right direction? I don't have a ton of money left over after buying the saftey stuff I needed for the car PLEASE HELP. Keith
Old Jun 21, 2003 | 09:44 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
Go to the TECH board on this site. There are several items telling how to convert TBI to TPI there.
Old Jun 22, 2003 | 04:32 AM
Svelte_SS's Avatar
Car: 1987 Monte Carlo SS
Engine: 5.7L TPI
Transmission: 4 spd auto
Buy some wire and make your own from a manual.
Old Jun 22, 2003 | 08:50 AM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
The would work.
http://chevythunder.com/speed_density_harness.htm
Or a Holley 950 Commander ECU and harness, $840.00 from Summit.
You would still have to have a harness for the starter/charging circuit.
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
