compression questions
Old Jun 24, 2003 | 09:24 PM
demon138's Avatar
Car: 89 Pontiac GTA Trans Am
Engine: T.P.I. 383 Stroker
Transmission: Monster 700R4
i am goin to build a 383 stroker with the following:
pbr 5.7 h-beam rods
speed pro .125 dome 10.8 compression
1 5/8 shorty hedmanns with y pipe
mild cam
stock stall convertor
ported intake and components
and stock l 98 heads
is the compression too high ?
will these parts work together ?
will it be much of a difference from stock performance?
Old Jun 24, 2003 | 10:03 PM
demon138's Avatar
anyone?
Old Jun 24, 2003 | 10:11 PM
FactoryFreak's Avatar
Car: 1988 GTA
Transmission: TH350
Your not going to accomplish alot with the stock l98 heads an stock converter. I would also setup to 1 3/4 inch headers since its a 383 and it needs to breathe. What do you mean by a mild cam? You won't see much of a gain over stock since your still using the restrictive stock heads. If you port or swap the heads, put a bigger stall, larger headers, and burn a chip you will see some very impressive gains. But til then it won't amount to much
Old Jun 26, 2003 | 10:30 PM
demon138's Avatar
what about the compression? will it be too high?
Old Jun 27, 2003 | 10:23 AM
ski_dwn_it's Avatar
Engine: 2 mice and a cat
You can probably squeeze by with some creative and careful tuning.
Your cam choice can make a difference too.
beastin91rs
Oct 9, 2015 07:38 AM
gixxer92
Sep 1, 2015 04:32 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
