Weird MAF readings
Old Jul 6, 2003 | 08:47 PM
3gc's Avatar
3gc
Car: Z28
Weird MAF readings
In april i finished my motor swap and i've been getting error codes every once in a while since. I was never able to read them by jumping the aldl terminals for some reason, but i finally got an aldl cable and a scanner hooked up and found out it's a code 33, high maf. I've been trying to get it to set the code while i was logging data but haven't yet.
But while looking through data i did log, i found some odd readings.
At one point, at 950 rpms, the maf was reading 31.24 g/s for about 5 seconds, i assume i was at a stop light here, then the next data point i'm at 50 mph and the rpms are 2100, yet the maf reading is 15.57 g/s. Until it goes back to idle it dosn't read correctly.
What could cause this? The maf sensor was replaced in april with a new bosch one. The relays however look original.
This is the log trimmed down to where it happened - Data Log
Thanks for anyhelp
Old Jul 6, 2003 | 10:22 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
vacuum leak. EGR valve sticking open.
Old Jul 6, 2003 | 10:39 PM
3gc's Avatar
3gc
Car: Z28
EGR has a vaccum cap over it, i'll look for vaccum leaks though.
Ghettobird52
Jul 5, 2024 11:18 PM
Cleotiz
Jan 6, 2018 08:56 PM
GTAman
Sep 21, 2015 09:57 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
CORV3TT3
Aug 23, 2015 11:26 AM
