Modifying computer after engine swap??
Old Jul 9, 2003 | 08:17 PM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
Hey guys I see all this crap about people having PROMs burnt and everything and I just have one question. Does this custom chip stuff only apply to people with MAP systems?? Doesnt a MAF automatically adjust air fuel ratios and should therefore not need any modification after being swapped to a bigger engine???
Thanks....
Old Jul 9, 2003 | 11:30 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
IF applies to MAF cars as well. The fact is that, at a calculated AIR intake by the MAF sensor, the computer with set tables of timing and fuel, add both for the specified air amount.
This is why MAF cars adapt so well to radical changes, however.... when you add say a bigger cam, technically bigger cams like more timing than the stock cam. Thus, you must change it in the chip.
If you just rotate the dizzy to increase Base timing, then you are lying to the ECM.
For instance.... you set base timing to 14ºadvanced, (stock is 5.98º), then when you are at an idle, and the computer puts timing to 19-20degrees... you are ACTUALLY at 28 degrees, because the ecm advanced timing from what it thinks the base is.
I hope that makes sense, and I know after my changes to TPI it helps to burn your own chip and make your car more how you want it. IE idle speed, fan turn on temps, etc.
Old Jul 9, 2003 | 11:33 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Go do some searching on the PROM board here and go thru the stickies at the top.
Lots of your questions can be answered and a lot of information there
LAter
Jeremy
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
