tpi l98 cam ?
Old Jul 13, 2003 | 04:15 PM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
Transmission: slipping 700r4, soon probuilt
tpi l98 cam ?
I have a l98 from a 89 firebird gta and was wondering were i can find the specs on the cam. Also could you give me some recommendations on upgrading the cam. the engine is stock the only thing i have done is put the hooker 2055 with 3 inch highflow cat and catback. but am plainning other mods in future (funds are low)
Old Jul 13, 2003 | 11:35 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Check the cam tech article on this website. I think its like 207/213, .415/.430, and 117 LSA for an 89 L98 cam.
Old Jul 13, 2003 | 11:52 PM
bigals87z28's Avatar
Car: Check The Sig
what is the displacement on your engine? I assume you have a 305. it doesnt matter i guess. the LT1 is good, but more up top power where TPI dont like it, ZZ4, and then LT4 hot cam. Also many cams from crane, comp, etc are all good.. it really depends on heads, TC and gears.. and where you wana go. Also, depends on if you have a roller block or flat tappet cam stock. what year is your car?
Old Jul 14, 2003 | 12:01 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
It's an L98 (=350) from an 89 GTA
What are your planned future mods?
Old Jul 14, 2003 | 12:33 AM
Car: Check The Sig
ohhhhhhhhhhhhhh he HAS the engine... i thought he ment the cam... oh sorry bout that... disregard the first few lines there... but deff swap out the cam...
Old Jul 14, 2003 | 05:42 PM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
I dont really know what my plans are for the engine at this point. dont know that much about tpi yet. but am planning on 342 gears and a posi
Old Jul 14, 2003 | 08:13 PM
Sunny RS's Avatar
Car: 89' RS
Engine: 5.0
what is the max cam lift on the 89' l98 heads that you can get away with without binding and such?
Vintageracer
Jan 10, 2020 05:33 PM
theurge
Aug 21, 2015 12:46 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
Sanjay
Aug 12, 2015 03:41 PM
anesthes
Aug 8, 2015 09:37 PM
