Another LT1 intake up and running!
Old Jul 14, 2003 | 09:44 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Just thought I'd let everyone know that I got my car running with a self converted LT1 intake that I had been working on. John and others were a great help along the way and I hope to have the bugs worked out sometime this week. Its been on for almost a week now and running. I have an oil leak to fix and a PCV/EGR problem to mess with(all my fault) but other than that it seems to be running pretty decent. I can't wait to get it all working right and take it to the track. I also put some 4.10's in a few weeks ago and those combined with this intake and my LT4 hotcam should produce some decent numbers I think. Here are my basic mods:
stock L98 bottom end
LT4 hot cam
gasket matched iron L98 heads
TPIS ZZ9 valve springs
comp 1.6 roller tipped rockers
LT headers and 3" exhaust
MSD and other ignition stuff
K&N
TPIS airfoil
custom chip by me (basically a stock L98 right now )
T56 6-speed
GM Motive 4.10s
I think thats about it. Before the intake, I pulled 275RWHP and 330 RWTQ with STOCK runners, 48mm TB, ported plenum, and a stock base that I siamesed. I'm hoping for closer to 300RWHP next time after some tuning. I also think I should be really close to 12.99s. What do you guys think? I'll post some pics sometime soon and definately a before and after ET! My best ET before the gears/intake was a 8.75@81mph in the 1/8th. I'm guessing that was about a 13.6@101 or so. Later
Old Jul 20, 2003 | 08:32 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
100 views and ZERO replies?????? Come on guys
Old Jul 20, 2003 | 09:24 PM
3504mula's Avatar
Car: 90 Formula
I think everyone is just jealous of your car, I know I am....
What gears were in before???? If they were 3.42's or numerically lower I think 12's are DEFINITELY possible, simply because that T56 needs 4.10's even without the LT1 intake. Get some stickier tires if you don't already have them.
I don't know about the dyno numbers, but that LT1 intake should wake up the cam you have so 20+ hp doesn't seem completely outrageous.
Good luck and your car kicks a$$!!!
Old Jul 21, 2003 | 09:24 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Man come on I'm blushing. LOL Thanks for the compliments. I think you said it right too. 12s and 300rwhp should be somewhat close. I agree with the T56 and 4.10's.... it needs them no matter what because 1st gear sucks! I had 3.42s before and they were ok but these are alot better. As for sticky tires I have 275/50/15 Nitto Drag radials. They should work good. I'll have new track times this weekend! Woohooo!
Old Jul 22, 2003 | 07:42 AM
Formula383's Avatar
Car: 88 Firebird Formula
What kind of fuel pressure are you running and also what timing? I did the conversion and just want to get some idea's.
Old Jul 22, 2003 | 01:35 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Some pictures please. I am more than interested in this setup! Thanks
Will
Old Jul 22, 2003 | 01:59 PM
SmokinZ28's Avatar
Glad you finally got that intake on
Old Jul 22, 2003 | 05:57 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
As for pictures, I don't have any uploaded yet but just check out www.lt1intake.com
I'm running stock fuel pressure and 8* initial timing. As for my chip it is mostly stock right now but I just got ahold of someone else's chip for some ideas on what I need to work on!
Old Jul 23, 2003 | 07:00 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Post some pic's of the intake swap..
Heres a peek at time.. Need to finish up a few details and put a 2nd coat of powder on it.
http://www.cecoatings.com/images/92Z...e/DSC00481.JPG
Old Jul 23, 2003 | 05:23 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Thats cool. Looking good. What heads/cam combo you running??
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Fast355
Dec 2, 2016 06:33 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
