TPI upgrades
Old Jul 21, 2003 | 09:16 PM
Rage13's Avatar
Car: 89 Firebird
TPI upgrades
I've got a TPI system i pulled out of an 88' 305, and am planing on putting it on my 84' 305. What kinda stuff would you guys suggest upgrading while I have it all apart and cleaning it? I belive I need to get a different intake manifold so it will bolt up to my heads, I was thinking about either going to edelbrock or TPiS for the manifold and SLP for some high flow runners. I plan on port and polishing everything inside and out too. So what else can you guys throw in?
Old Jul 23, 2003 | 08:36 PM
Rage13's Avatar
Car: 89 Firebird
no comments? I know there must be more i can do then what i posted..
Old Jul 23, 2003 | 08:54 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Ummm....as far as intake work you just about mentioned everything.
Aftermarket runners and base
Ported & Polished the plenum, base, and runners.
There are other things to do, but the question is are you going to need the air flow of a larger throttle body?
Old Jul 24, 2003 | 04:40 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
a slighty better cam than the stock one. i'd change that now rather than later. also get one with around 112* LSA.(computer freindly cam)
Old Jul 24, 2003 | 05:01 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
you dont need a different intake to bolt up to the older block, you judt need to elongate the center 2 bolt holes on each side. Unless you still want to upgrade.
gta90
Sep 15, 2015 04:00 PM
jbd1969
Aug 17, 2015 07:06 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
