Helps with some parts im needing for my motor
Old Jul 25, 2003 | 05:01 PM
Spdfrk1990's Avatar
OK im building a 383 i want like around 450 rwhp.
I alrdy have the bottom end i want crank,rods,pistons
Now there r just some little parts i want to ask u guys where i should get them ok what about the timing chain its a 00 block roller of course zz4 crate motor block. I want a double roller where could i get 1 also what about a cam button. Oil pump and oil pan which 1's would u recamend. Its a 4 bolt main should i use main studs?? Just if some1 could list all the little things that r usually over looked and where should i get them.
i alrdy have the cam intake and heads in mind i want the cc306 cam,fast burn heads, and mini ram III.
any oppinions would be great thanx i want the engine to turn out best as possible.
Old Jul 30, 2003 | 06:15 AM
Spdfrk1990's Avatar
any1??
reiderz iroc
Aug 13, 2015 04:57 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
guy76767
Aug 6, 2015 05:58 PM
