Possible setup idea work with stock bottom end???
Old Jul 27, 2003 | 06:54 AM
IROC350TPI's Avatar
Car: 89 IROCZ28
Engine: 350TPI
Axle/Gears: 2.77 Gears
I'm looking at adding some parts to my 350TPI engine and I'm wondering whether the stock bottom end will hold up. Basically I'll be bolting on a Superram intake and manifold, LPE 219 cam and AFR190 heads along with a set of headers, #24 injectors and a few other items. I'm planning on running this car at the track and just want to make sure that I don't need to pull the short block and rebuilt the bottom end with better components. I'd really rather not blow it up because it is my daily driver and I need it running. BTW...the motor as of now has just over 80,000 miles on her. Thanks in advance.
Ryan
Old Jul 29, 2003 | 01:54 PM
IROC350TPI's Avatar
Car: 89 IROCZ28
Engine: 350TPI
ttt
Old Jul 29, 2003 | 07:39 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
As long as your bottom end is sound now, it should be ok for awhile. My bottom end was shot so I had it rebuilt. I reused the crank and rods and put in forged pistons. It's holding up great. And with this combo, you shift around 6000 rpm, so you aren't spinning the motor to the moon, which helps with longevity.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
