Slight stumble off idle when cold??
Car: 00 Trans Am/89 IROC
Engine: LS1/L98
Transmission: 4L60/700R4
My IROC has been acting weird lately. It has developed a cold stumble right off idle plus when you first start it cold it idles really rough and almost wants to die for about 5 seconds then it clears up but still hesitates under part throttle till it warms up. I just did a tuneup on it but it didn't help.
What next?
What next?
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Can u pull any codes out of it? could be something simple as resetting the iac and tps if they havent been adjusted for awhile, also check your throttle body for coking and if it is clean it out and then reset the tps and iac directions are on the tech pages
Later
Jeremy
Later
Jeremy
Engine: LS1/L98
The fuel filter is old. Hasn't been changed since I bought the car....back in 96
guess it wouldn't hurt to change it. The air filters are new. I'm gonna work on it tonite. I'll pull the throttle body, clean the iac and ajust it and the tps and reset the computer and see if that helps.... oh and put my chip back in since I finally passed emissions
fuel filter would be a costant problem, would not clear up in closed loop. If i was going to guess i would say vacuum leak. but
thats just a guess. with out the right dianostic tools all anyone on here really has is just a guess. good luck
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
i have the same problem, except i have new everything. fuel filter, K&N's, tune up, oil change........ still does this in the morning. I think i need to adjust the tps and what not
Will
Will
theshackle
Sep 17, 2020 08:26 AM
