Oil Pressure @ Elevation?
Old Jul 31, 2003 | 01:09 AM
PONTIMANIAC 90's Avatar
Car: 1990 Formula
Engine: treefitty
Transmission: stick
Is it possible that at higher altitudes(mountains vs. sea level) oil pressure would be lower?
Old Jul 31, 2003 | 06:58 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I wouldn't think atmospheric pressure would have any relation to fluid pressure that's built mechanically.
Old Jul 31, 2003 | 10:21 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
I would agree. Atmospheric pressure should have no effect on oil pressure.
Old Jul 31, 2003 | 05:07 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Look at it this way. Oil pressure is determined by a byoass spring. More pressure on the bypass valve (like say, more air pressure) will naturally make it proportionally more pressure closed.
Don't believe me? What happens when you hook vacuum up to a TPI FPR?
Old Aug 1, 2003 | 01:24 AM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
The reason I asked is that when I was in the Poconos my oil pressure got halfway bellow the 30 mark with car warmed up. I got worried since I got a new motor and the pressure is normally pretty high. Even in 90 degree heat in NY it stays between 30 and 60, closer to 60.
I'm going back to Poconos this weekend again and I guess I'll see if it drops again.
Old Aug 1, 2003 | 01:47 AM
IROZINCO's Avatar
Oil pressure at altitude
Well, i don't think anything east of the Missisippi gets above 6000 feet. I live in CO at 6500 feet and regularly drive up to 10,000ft. I have never noted a difference in my oil pressure, either at speed or at idle. In our cars, temperature affects OP more than anything else (assuming sufficient volume, of course!)
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
