Plug gap
Old Aug 7, 2003 | 03:09 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Plug gap
Im running a 383 stroker motor with tpi. What would be a good plug gap for my setup? I think stock is .35, but not sure if this would be fine.
Old Aug 7, 2003 | 10:36 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
Will need to know the year model of your engine and whether you have cast iron or aluminum heads. This will determine your plug gap and plug heat range. I have Platinum +4 in my Vette. No worry about gap.
Old Aug 7, 2003 | 10:39 PM
shaggy56's Avatar
Car: 71 Nova
Well the engine is a 4 bolt main from a light duty truck thats all i know. The heads are iron 76 cc with 1.92 1.5 valves
Old Aug 7, 2003 | 10:40 PM
shaggy56's Avatar
Car: 71 Nova
Well the engine is a 4 bolt main from a 1980 light duty truck thats all i know. The heads are iron 76 cc with 1.92 1.5 valves. Im running 9.5 : 1 comp if that helps. Im also running comp cams 12-268-4 cam
Old Aug 8, 2003 | 09:41 AM
Morley's Avatar
.035-.040" to start, check performance and increase .005-.010" until performance suffers, then put it back to the previous gap (before performance was lost) and maybe close it another .005".
Old Aug 8, 2003 | 12:37 PM
shaggy56's Avatar
Car: 71 Nova
Thanks for the info. I read the more comp and modified an engine is that you need a tighter gap.
Old Aug 8, 2003 | 12:53 PM
Morley's Avatar
Yeah, but 9.5:1 is the "stock" compression on a TPI engine so start at stock gap and go from there, no one can tell you the "magic" number for the gap, it is something you'll have to play with and find what works best for your combo.
Old Aug 8, 2003 | 12:57 PM
shaggy56's Avatar
Car: 71 Nova
Exactly what im going to do thanks for the help.
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
