throwing 3 codes i dont understand
Old Aug 17, 2003 | 12:34 AM
91CamaroRS305's Avatar
Car: Only a daily driver, but comin home
Engine: I have one that runs ;)
Transmission: Caged hamster that runs really fast
Axle/Gears: They are round, I know that much
i ran my codes and came up with a
22 (22. Low voltage at throttle positon sensor OR Fuel cutoff relay circuit open or shorted to ground)
24 (24. Circuit fault in vehicle speed sensor)
33 (33. High voltage (low vacuum) at mass air flow sensor (or MAP sensor)
and i dont understand the meaning behind them, i have a problem with running rich, and was wondering if that code 22 could have something to do with it, as for the other 2 i have no idea what they are for, any yeoman explaination would be better
thanks for any info
damn publick skool edikation!!
Old Aug 17, 2003 | 09:28 AM
llvll4l2c91350's Avatar
i'd start off by clearing all the codes, and see how many come back.
Old Aug 17, 2003 | 09:11 PM
i reset the car and sure eough they returned after a about 20 mins of driving, the only thing i know is that i am running rich, but that is all the trouble i am getting, any ideas?
Old Aug 18, 2003 | 01:16 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Check the specs to make sure your TPS is set correctly and that there are no loose connections there or at the MAF sensor.
92firebirdguy
Sep 1, 2016 07:53 AM
BumpaD82
Feb 26, 2016 02:57 PM
86IROC112
Nov 27, 2015 09:54 AM
gta892000
Sep 16, 2015 12:37 AM
3rdgenkindagal
Sep 13, 2015 02:02 PM
