STB hits TPI after polly engine mounts.
Old Aug 17, 2003 | 09:28 AM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
Anyone else have this problem and if so what should i do to fix it. I like the stb it makes turning so much tighter.
Old Aug 17, 2003 | 09:43 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Make some shims out of flat aluminum stock to build up the height of STB.
Note mine under the support brackets.
Old Aug 17, 2003 | 12:08 PM
metalhead212121's Avatar
Car: 91 Firebird Formula
Engine: For me to know.....
Transmission: and you to find out....
the reason why this is happening is because with Poly mounts the engine sits higher. a lot of people have had this problem...hate to tell you this but Im pretty sure most people end up ditching the poly and going with quality GM motor mounts. Good Luck!
Dan
Old Aug 17, 2003 | 02:19 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Definately go with DJ's idea, keep the poly mounts.
Old Aug 17, 2003 | 09:30 PM
25THRSS's Avatar
any vibration with the poly mounts?
Old Aug 18, 2003 | 08:32 AM
91RS5speed's Avatar
Car: 91 RS
Im going to do the shims were is the best place to get metal like that?
I didnt notice anymore vibration from it. I did notice some when I put the poly trans one in a while back.
Old Aug 18, 2003 | 10:07 AM
DJP87Z28's Avatar
Originally posted by 91RS5speed
Im going to do the shims were is the best place to get metal like that?.
Try any hardware store or a big box one like HOME DEPOT. Any flat stock 1/8" should work. With the small thickness you can check to see how much you will need for clearance over the TPI. Just remenber you also have the hood clearance.
Old Aug 18, 2003 | 07:18 PM
Krag's Avatar
Engine: 406 w/TPI
Transmission: 6-speed
I read that using Poly mounts can give the knock sensor false vibrations from the chassis and cause the timing to retard. Mainly using them on the transmission mounts. Anybody else hear about that?
Old Aug 18, 2003 | 07:47 PM
I run poly motor mounts and stock tranny mount and noticed no retard increase after the swap.
Old Aug 18, 2003 | 09:25 PM
Krag's Avatar
Engine: 406 w/TPI
hmmmm... I guess the story is bunk then! I can't see how the suspension and road noise could duplicate 'ping'.
Old Aug 19, 2003 | 02:47 AM
OMINOUS_87's Avatar
The further away from stock you go the bigger the PITA a STB becomes.
My motor sits on poly mounts with a Superram intake. My Hotchkis STB is bolted all the way forward on the strut towers for max clearance. While the STB cleared the motor I had to pull the hood insulation and cut out the middle support so the STB would clear the hood.
Old Aug 19, 2003 | 12:17 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I have all mounts energy suspension poly-urethane and I have plenty of room with my Hotckis brace.
Old Aug 19, 2003 | 01:40 PM
DJP87Z28's Avatar
It depends on the car if you have clearance or not the over TPI with the STB, variables exists.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Caspar
Jun 19, 2016 11:19 PM
MY87LT
Aug 17, 2015 08:43 AM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
