Hypertech chip
Old Aug 17, 2003 | 01:24 PM
volksjager's Avatar
Car: 1987 Z28
Transmission: TH700-R4
Hypertech chip
i just installed a hypertech thermomaster chip in my 87 IROC.
it now has less power,the check engine light is on, it idles at 1500RPM and the car wont comunicate with my scan tool. I took the chip out put the stock one back and the car runs perfect. the car has a 160 stat , a 185 fan switch, adjustable fuel pressure regulator set at 50 psi, headers no cat and a borla 3" exhaust. any advice??
Old Aug 17, 2003 | 02:29 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Whoa!! 50psi!!!! I think your looking for the TPI board, not TBI. It's all good though. Hypertech chips are no good to begin with, and I would try to return it for a full refund if I were you. However, my guess would be that you have the wrong chip for your engine. If you are set on using a hypertech chip, then check the number on the chip, call hypertech, and make sure it is the one for your car, i.e. correct year, engine size, manual or automatic, etc. Best of luck
Old Aug 17, 2003 | 02:49 PM
volksjager's Avatar
Car: 1987 Z28
yes i screwed up it is a TPI . I bought the chip from Summit so im sure they will take it back. What should i do for a chip instead. Is JET or Superchips any better? How much improvemant is a chip really worth anyway?
Old Aug 17, 2003 | 06:48 PM
Engine: LO3;383tpi
The general concensus is that aftermarket chips to include tbi and tpi suck. Period. Use the $150 or so on other mods instead, or put the money towards chip burning equipment. I had almost the same exact mods as you did when I installed the thermomaster. I didn't feel anything-if I knew better, I would say it slowed me down. To find out more info on after market chips, try a search. Much has been discussed on them.
Old Aug 20, 2003 | 08:37 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
i bought a superchip for 200.00$, and noticed absolutely no difference, I think it actually slow me down. It made my car miss and run like crap. But i was able to get my money back.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
