Converting TBI harness to TPI...need help
Old Aug 18, 2003 | 11:03 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
I have a tpi harness off an 85, which I would rather not use because of the spliced wires it contains. I have been looking through wiring diagrams for a 92, and I've noticed that there aren't many differences between a tbi and tpi harness. I am going to keep looking through and make notes of all the differences I see. So far, this is what I've noticed. Please feel free to correct me or add anything I have missed.
I believe the tps and iac wiring would be too short on the tbi harness, so I would need to remove those, and replace them with the wires from the tpi. Would need to do the same with the injector wiring. I also know I would have to repin the connections at the ecm. Anything else I haven't noticed yet?
Old Aug 18, 2003 | 11:23 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Wires
Yes, you will need to eliminate the ESC module (jump the wire from the knock sens. to the wire that goes to the computer),change the knock sens., and change the plug for the EGR. Under the dash you will have to eliminate the speed buffer (jump the two brown wires together), run the yellow and the purple down to the computer, and run the red wire on the speed buffer to the computer. In the 15 pin connector, you will need to eliminate the purple/white wire.(it's for crank fuel not used on TPI)
MustangBeater20
Oct 29, 2022 09:20 PM
camaro11j
Sep 19, 2018 08:49 AM
TheJoeY88
Dec 31, 2016 07:30 PM
Keith5
Aug 27, 2015 04:37 PM
92purpz28
Aug 11, 2015 02:30 PM
