Will afr 190's work with HSR?
Old Aug 22, 2003 | 01:18 AM
snowman89's Avatar
Car: 1989 IROC-Z Camaro
Engine: 5.8L 355
Transmission: T-5 5-speed
I would like to get HSR and bolt some heads to it, I was just wondering if afr's 190's will work. I also want to know what it would take to put HSR on a TPI...can I just buy the manifold and fuel rails, and not have to worry about the whole system???
Old Aug 22, 2003 | 02:06 AM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
ok, for starters, the AFR heads will work fine with a HSR because i don't think the HSR uses either of the new intake bolt patterns, I'm not real big on fuel injection stuff, but i think you have to change a fair amount more than just the manifold/rails
Old Aug 22, 2003 | 09:13 AM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
Yeah all you'll need is the intake manifold and the fuel rails. You might need something else, but I'm pretty sure it'll be minor. I'm sure someone lists all the stuff you need, try to search.
David
Old Aug 22, 2003 | 09:14 AM
bigals87z28's Avatar
Car: Check The Sig
umm... the HSR has standard bolt pattern, not vortec... HSR and AFR190's should go together fine. and HSR on TPI? how would one do that? Umm you need the fuel rails, get the AFPR, plenum, intake, and you can reuse the tb and the EFI set up. it is NOT emissions legal.. .just a reminder.
Old Aug 22, 2003 | 10:42 PM
snowman89's Avatar
Engine: 5.8L 355
I don't care about emmissons at all...I'm taking my cat off my exhaust......So pretty much you just get the HSR, and don't need the system......well thats good, and lots cheaper...But would you recomend AFR 190's along with the HSR????
Old Aug 23, 2003 | 07:34 AM
grumpyvette's Avatar
HSR is an excellent match to the AFR190cc heads, especially if the cam you choose has at least 216 or MORE intake duration and your useing a free flow exhaust and headers that let the system as a combo use that better airflow
Old Aug 23, 2003 | 11:23 AM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
look around at www.stealthram.com for some of your answers.
Old Aug 31, 2003 | 07:08 PM
onetontj's Avatar
What size heads would you guys recommend for a 406ci with the HSR. I've seen 383 motors with 190cc afrs produce outstanding numbers...seems they would be restrictive on a 406?
Old Aug 31, 2003 | 09:44 PM
Car: Check The Sig
there are several good set of heads. Depends on if you want to go iron or aluminum? and that depends really on your compression ratio.
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
355tpipickup
Aug 19, 2015 10:02 PM
355tpipickup
Aug 13, 2015 07:35 AM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
