Interference between accessories and topline heads?
Old Aug 26, 2003 | 07:05 PM
66_C10_TPI's Avatar
Does anyone know about interference problems between 180cc cast iron pro topline heads and the stock serpentine setup (92 camaro). Such as alternator, ac compressor, etc. I have heard that there are issues with bolt holes missing or not aligning with brackets. I would like to use these heads but do not want to have to get to get an aftermarket setup.
Old Aug 28, 2003 | 06:59 PM
66_C10_TPI's Avatar
There isn't anyone using Pro Topline heads with the stock serpentine setup???
Old Aug 29, 2003 | 01:45 AM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
I haven't quite bolted the brackets up yet...but I did notice when I test fit the pass side one that only 3 bolt holes line up...should be fine though...but I need to check the driver side.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
