adjustable fuel pressure regulator??
Old Sep 6, 2003 | 08:36 PM
puckyou's Avatar
what does an adjustable fuel pressure regulator do exactly? is it hard to install? would u recommend it ?. anybody have any comments on it. thanx
Old Sep 6, 2003 | 08:48 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
well it does exactly what it says. you can adjust the fuel pressure. not too hard to do. just remove the plenum and remove old one and install new one. and of course i recommend it. can pick up a couple of hp with it.
Old Sep 9, 2003 | 12:23 AM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
What is involved in changing the regulator though? What type of fittings?
Old Sep 9, 2003 | 12:49 AM
bigals87z28's Avatar
Car: Check The Sig
nothing really. The kit comes with everything you need. I sugest Holley's AFPR. It seems to be the best quality and easy to turn **** instead of a tiny screw. There might be a little grinding of the plenum to make it fit, but some people have had better luck. An afpr is a great tuning tool. I plan on getting the holley unit as soon as i get a job!. dam school.
Old Sep 9, 2003 | 08:38 AM
ski_dwn_it's Avatar
Engine: 2 mice and a cat
The main purpose of the regulator is much more complex than people think. Its function is to keep a constant pressure on the injectors.
At idle there is a large vac in the manifold so the regulator trims back the FP with the manifold pressure as the ref. At WOT the manifold vac is zero or atmospheric pressure, so there more pressure is needed to maintain that pressure differential across the injector.
Without the regulator being able to adequately regulate the pressure, its in a sense changing the injector size as a function of your right foot. Not a good scenerio.
On a different note the Holley regulator is a great setup, and one I will most likely put on the next time I take my intake off.
Old Sep 9, 2003 | 06:02 PM
puckyou's Avatar
i got the one from TPIS. anybody hear anything about that one.
Old Sep 10, 2003 | 01:26 AM
sllt1776's Avatar
Car: 89 Iroc-Z
i heard it is ok but the nipple is prone to breaking off. maybe just older design. who knows about the newer ones.
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
