estimates on 1/4 mile times for a 305??
Subscribe
Sep 10, 2003 | 09:33 PM
I'm trying to work out what I might make in the 1/4 mile since I don't have time to make it out to the track to see what it will really be so I thought I'd ask you guys.
My setup consists of:
- 305 LG4 converted to TPI
- LT1 cam
- 700r4 tranny
- 3.27 gears
- Subframe connectors
- 22lb injectors/350 ECM (that's what came with TPI setup...plugged scanner into ECM and I'm not running rich so I'm cool )
Mods to engine besides cam:
- TPS set to .65
- cut air bottoms off air cleaner
I've estimated the car weighs about 3400-3500lbs just from ruff guestimations. So yeah what do you think it will do in the 1/4 mile and any ideas on what I can do that is free/cheap that would help me out a bit.
Thanks,
Mark
Reply 0
Sep 11, 2003 | 02:23 AM
i'd say mid to low 15s
Reply 0
Sep 11, 2003 | 05:17 AM
Re: estimates on 1/4 mile times for a 305??
Quote:
- TPS set to .65
Mine was set at .65 and I found that it was actually .3 slower in the quarter as opposed to the correct setting of .54.
Reply 0
Sep 12, 2003 | 04:29 PM
so what could I do to make it get into the low 14's?.....besides droping in another engine :-)
Reply 0
Sep 12, 2003 | 05:37 PM
My LG4 5 speed with a Edelbrock carb and intake swap, stock manifolds, stock exhaust, ran a 14.94 @ 91.67mph.
I did a TPI swap with cam, TPI heads, SLP Dual CAI, MSD 6A, Blaster 3 coil, Dynomax shorty headers, custom y-pipe, 3" catback, 52mm tb, 19lbs injectors, and I ran a 14.1@99mph with the car running in limp home mode.
Here is a 15.24 run with the LG4, http://www.transamws6.com/video/Manny_vs_Charles.mpg
This is a 15.04 run,
http://www.transamws6.com/video/Manny_1504.mpg
Here is the car after the TPI/Cam swap,
http://www.transamws6.com/video/ZepherWS6.mpg
Reply 0
Sep 12, 2003 | 06:07 PM
I was kinda hoping there was something I could do that wasn't going to cost that much......while I'd love to do those things I rather don't have the cash to do them right now.... ohwell....
Hey Zepher....Do those headers allow for easy or semi-easy access to the spark plugs?
Reply 0
Sep 12, 2003 | 06:21 PM
Plug access was pretty easy since there aren't any AIR tubes on them.
I have Hedman Longtubes on my LT1 in my 86 and plug access is super easy. I can do plugs in less than 5 minutes.
Reply 0
Sep 12, 2003 | 06:27 PM
Thanks, now I've got an idea on which headers to get . maybe exhaust next summer.........or paint...........or rims............or new engine.........or...........
Reply 0
Sep 12, 2003 | 10:07 PM
as your car sits now...id say you have a low 14 in it
Reply 0
Sep 13, 2003 | 12:30 AM
ifyou car is properly runing nd on a good day i woukld say a high 14. but
Reply 0
Sep 13, 2003 | 05:55 AM
My vote is very low 15's.
Reply 0
Sep 13, 2003 | 07:07 PM
mid 14s
Reply 0
Sep 13, 2003 | 11:04 PM
I'm curious.......do you think it would run better with a 350 or 305 ECM?
Reply 0
Subscribe
