350 into 383...?
Old Sep 11, 2003 | 07:11 PM
Akshay's Avatar
350 into 383...?
If I get a 383 stoker kit (bump the 350 to 383), do I have to modify the timing. Or will the stock timing be okay.
I live in California. So, do you think I'll pass emissions with a 383 stroker kit?
Akshay
Old Sep 11, 2003 | 11:34 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: 350 into 383...?
A 383 uses a 3.75" stroke so the piston speed increases and the required timing advance is just a little bit less, but no big deal.
Yeah as long as your stroker kit is still packed in the box it came in you'll be okay.
Old Sep 12, 2003 | 03:47 AM
Z69's Avatar
Z69
It'll smog okay depending on the cam and how the chip is tuned. Stock cam and chip setup for 383 and bigger injectors should pass no problem. But who runs a stock cam?
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
