HSR installation
Old Sep 21, 2003 | 07:41 PM
thirdgencompta's Avatar
HSR installation
I just put a holley stealth ram intake on my GTA and after some modifying, I got it to fit...BUT I took 2 sensors off the front of my old TPI intake and only one of them fits my Stealth ram. Do I need both? they both look like temp sensors...I also have my old TPI base, plenum and runners for sale if anyone wants em.
Old Sep 21, 2003 | 08:10 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Well, yes and no..
You probably took the CTS (neeeded...without a doubt) and the Cold Start injector plug off...which isn't absoluetly needed....but you'd want to have an eprom burned from an '89, w/o vats..assuming your GTA dies not have VAT's.
Old Sep 21, 2003 | 08:16 PM
Uh, I have the prom thing covered...but the 2 sensors went into the coolant ports on the front of the intake...what are both of them? they were 2 different sized threads
Old Sep 21, 2003 | 08:23 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Uhh..so...I'll...speak...slower..
You most likely rmoved he CTS (CoolantTemp sensor) that is used for the ECM...YOU NEED THIS!!!!
Other one was the CSI (Cold Start Injector)...that since you "have the prom thing covered" will no longer be needed.
Got it?
Old Oct 5, 2003 | 10:34 AM
BOTTLEDZ28's Avatar
Transmission: A4
in order to get that other sensor working again and will need to buy a reducing fitting.
Mike he said he took 2 sensors off the front of hisintake and if I recall, the CSI is on the side of the intake. whatever the case if the 2 sensors are needed then a threded brass reducing fitting will be needed and can be bought at any parts store
Old Oct 5, 2003 | 05:24 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
Re: HSR installation
Just curious...what did you do to get it to fit?
Old Oct 5, 2003 | 05:57 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
The timeswitch for the CSI is on the front of the intake as well, next to the CTS...you're correct that the CS Injectopr is on the side of the intake..I shouldn't have said "plug", but "Thermistor".
Musta been a 40 oz. -night/day
Old Oct 5, 2003 | 08:10 PM
trigger GTA's Avatar
Car: 92 TA vert
thirdgencompta
are you still running your stock hood? and if so how well did the Holley fit under it?
Old Oct 5, 2003 | 09:34 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
the larger sensor is for the cold start injector. not needed any longer because of no 9th injector. toss it. the smaller one is the coolant temp sensor for the ECM. needed. keep it.
redmaroz
Apr 25, 2017 07:14 AM
trevor1010
Aug 26, 2015 02:41 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
trevor1010
Aug 24, 2015 11:29 AM
355tpipickup
Aug 22, 2015 06:06 PM
