Car problems again. Won't stay running.
Ok, so lately the car has been acting a lil weird. Sometimes when i would start the car, it would start up, but idle reeeaaallly low. Like normally i can hear the car just fine while it's idling. but sometimes it just idles so quiet that i can barely tell it's running.
So this morning i go out to go to work, i start the car, it's idling REALLY low, then stumbles and dies. I tried to start it back up several times, but it just dies if i let it idle. If i give it gas, it revs just fine, and sounds good, but dies at idle.
Now my first guess is that it is my fuel injectors. I have had 3 of the 8 replaced about 2 years ago, and they shop told me there were a couple other injectors that were clogged and dying. Unfortunately i didn't have the money to fix them then, but the car has been doing great till now.
Well, i just wanted some other ideas. I already ordered the new injectors from SLP, #25's, and they should be here by Monday. Anyone else agree that this sounds like injectors? Thanks for the help.
Car: 1990 Formula 350
Engine: 5.7
i believe its on the throttle body--not really sure what side tho--actually i think it is on the bottom half of the passengers side of the throttle body....i think there is a tech article somewhere youll have to look a littl ebit ont he main homepage...
later
later
Car: 1986 Iroc-Z
Engine: Stock 305 TPI MAF w 148,000 mi.
Goto the main page, click on Technical articles on the left, then under the Carbs/FI category, you'll find the IAC and TPS adjustment article.
Good Luck
Good Luck
well when those died, the car started stumbling a little bit. I pulled over, and the car died. I started it back up, and it seemed ok so i tried to get it home. After about 2 blocks, the car died and won't not fire back up. Just turned over n over n over. Mind you, this was 3 days after i bought the car. I think it wasn't used to my driving.
So i finally had it towed to the shop (a chevy dealer
) and they charged me 917.80 to change 3 injectors!!!
Yah i thought it would have been impossible for me to change them...i knew nothing about my car then.
Ghettobird52
Jul 5, 2024 11:18 PM
theshackle
Mar 5, 2017 06:37 PM
db057
Aug 11, 2015 10:11 PM
