What kinda numbers with this combo?!
Was wondering what kinda RWHP/TQ numbers this combo would produce...also some 1/4 times it would be capable of on a 350.
58mm TB
Hooker 2210s LTs
AFR 190cc Heads 2.02-1.60
TPIS ZZX cam 1.6 RRs
TPIS Prom Level 5
TPIS Miniram
22lb stock Injectors/Fuel pump <----need bigger injectors???
Stock Suspension
58mm TB
Hooker 2210s LTs
TPIS Prom Level 5
TPIS Miniram
Stock Suspension
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Use 195cc heads and 30lb SVO injectors. If you can tune your own PROM then you are looking at OVER 350 to the rear wheels. I'd guestimate ~380rwhp through an automatic. I made 364 with a cam that's not as good as the ZZX.
Tim
Tim
Re: What kinda numbers with this combo?!
What combustion chamber volume are you running, and what pistons? Compression plays a big role so let us know.
58mm TB
Hooker 2210s LTs
TPIS Prom Level 5
TPIS Miniram
Stock Suspension
58mm TB
Hooker 2210s LTs
TPIS Prom Level 5
TPIS Miniram
Stock Suspension
The compression should always be MATCHed to the combo. But, how important is it really? I ran 364rwhp with a weak ~9.75. Who knows. I know more would be better with the bigger cams but how much of a difference does it really make as long as you are around 10:1?
Tim
Tim
3.8TransAM
Sep 27, 2015 08:37 PM
tcflint
Sep 27, 2015 05:58 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
