Rocks in a tin can sound and other sounds
Old Oct 15, 2003 | 12:39 AM
bigals87z28's Avatar
Car: Check The Sig
Im 99% positive that its detonation of some sort. I had scanned the ecm with winaldl and it said my BLM's are at 150-158. This has never happend and i wana know why im so lean? My timing is 7-8*. This is probably giving me the great fuel economy,but crappy et's. Im very fuel starved over the power band. Im thinking of buying an AFPR soon, but I want to know wtf happend! I checked all the vaccume lines around the fpr to see if thats it. No problem with that. Also, there are these 2 other noises, one is a hissing, superchager-like sound, and this tapping noise that can only be heard while in the car... Its not a rocker problem.. that would be louder and I could hear it from the engine. Any insight here? thanks
Alex.
Old Oct 15, 2003 | 05:23 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
hissing+lean=vacuum leak
Old Oct 16, 2003 | 12:17 AM
Car: Check The Sig
TTT please fellas i need some help or some insight.
Old Oct 16, 2003 | 08:32 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Try to locate the general area of the hissing sound, then spray around that area. I'm with 91teal, hissing+lean=vacuum leak.
Old Oct 16, 2003 | 11:11 AM
shawn87gta's Avatar
"Rocks in a tin can" sound could be loose material inside the catalytic converter. That's how some muffler shops check them, they listen for stuff popping around loose inside. This may worsen as you rev the car when more exhaust pressure is present. Some of the catalytic crap may have blown back into the muffler and be making noise there too. Just a thought...
Old Oct 17, 2003 | 01:35 PM
Car: Check The Sig
The cat is brand new, so i dont know about that. And the sound is coming from the engine.. I thought it was detonation in the manifolds. As for a vaccum leak, I cant hear it when i open the hood and listen for it.. but when in the car, i deffinatly can hear it. Its very small, but I can hear it. Im thinking around the runners or something.. but other then that, i dont think its a hose. Im gunna have to check it out when I go home again. thanks.
Old Oct 18, 2003 | 09:32 PM
CamaroStud1988's Avatar
Car: 91z28 and 88 SC thats for sale,in the sig
Engine: 305 TPI soon 383 stroker or 327
Transmission: t-5
a good way to check for vacuum leaks is take a propane cansiter,and let it flow a little bit and just pass it over anywhere u may have a leak,if the idle goes up its where ur leak is. the propane is heavier than regular gas so it will settle down in low areas,just dont ahve the engines fans on,lol. the hissing may be a fuel leak also? mine leaked at the pressure regulator,if u havent yet,check the fuel pressure. GL
Old Mar 25, 2007 | 08:50 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
Re: Rocks in a tin can sound and other sounds
i had a vacume leak on my power brake booster that I could only hear from inside the car. But that only happened when I was on the brakes.
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
