New ETs with DRs
Old Oct 16, 2003 | 01:02 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
New ETs with DRs
Previous best was 13.22 @ 109.44MPH with 2.22 60ft
with an 1/8 of 8.669 @ 84.92 MPH
First run:
60 ft: 1.889
1/8: 8.336 @ 83.996 MPH
1/4: 12.928 @ 107.893 MPH
_______________________
Second run:
60 ft: 1.997
1/8: 8.424 @ 84.410 MPH
1/4: 12.994 @ 108.665 MPH
________________________
Third run (last):
60 ft: 1.933
1/8: 8.212 @ 85.831 MPH
1/4: 12.738 @ 108.048
_________________________
I had a rocker come loose during the 3rd run so I went straight home.
I was hoping for better 60ft times but I guess I need to do a longer burnout. I'm still used to cleaning off street tires for just a few seconds. My first run I actually did the longest burnout.
I did bump up the FP about 2 psi before my last run and that seemed to help.
Old Oct 16, 2003 | 07:45 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Hey Danny,
I have found the following burnout routine to be the best for my BFG DRs....
First air those DRs down to 18psi. Start your burnout in first gear. Shift to second. After shifting into second look in your side mirrors and MAKE SURE you have smoke coming from both tires. Once you have smoke coming from both tires then count to 5 ... 1-mississippi, 2-mississippi, etc. It might look stupid but it has helped me seriously hook up. In times where I couldn't hook up I have aired them down 1PSI at a time (down to 15psi at the lowest). The burnout along with the pressure changes will work.
What stall converter are you running? With 109mph you should be able to hit 12.5's.
Tim
Old Oct 16, 2003 | 09:03 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
I am still running the stock stall converter for now
My lowest tire pressure was 22psi.
Thanks for the tips on the burnout :hail:
Old Oct 16, 2003 | 09:08 AM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
I do the EXACT same thing Traxion said. It works well.
Get yourself a Vigilante!
Good times, you're on your way to low-mid 12's.
Old Oct 16, 2003 | 10:44 AM
TRAXION's Avatar
Danny,
DEFINITELY get a Vigilante under that car (2800-3000 would be ideal). Your 60ft times will drop to 1.6x. That's an extra 0.45 in the quarter! You need that converter!
Tim
Old Oct 16, 2003 | 03:55 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Don't you think a 2800-3000 would be too high for a 383/SuperRam?
I see that Buckeyeroc has a 2200 with a similar combo. I was toying with the idea of a 2200 or 2400 stall. How much are those going for now and is Vigilante the one to go with?
Old Oct 16, 2003 | 05:53 PM
BuckeyeROC's Avatar
I've been told by vette guys with this combo that 3000 stall is ideal at the track. But I can't hook on the street with the low stall I have, so raising it would only make it tougher. And I do use the dr's on the street.
Old Oct 16, 2003 | 07:11 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Hmmm, OK thanks. I don't want it to be too unstreetable though and I really don't want to save for a new rear end (have Borg-Warner 9 bolt with 3.45 now). I'll shop around for prices.
Old Oct 16, 2003 | 07:24 PM
TRAXION's Avatar
Danny,
2800 is absolutely, positively VERY streetable so long as you go for a quality converter like the Vigilante. In fact, my 3600 stall is SOOOOOOOO streetable that I wish I would have got a 4000 stall. I originally had a 2800 stall when I had the LTR setup and it was incredibly tight at part throttle and unbelievable at WOT. You will NOT be disappointed. It's a beautiful device. You'll love it. Do a search on TGO and you'll find all that you are looking for. Everyone with a PI Vigilante has been incredibly happy with the outcome. I went from a 13.0 on a 1.99 60ft to an IMMEDIATE 1.71 60ft. These were back to back with no changes. Get it and definitely go with at least the 2800. Don't go lower.
Tim
Old Oct 16, 2003 | 07:50 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Now you have me thinking about spending more $$ Vigilante
Old Oct 16, 2003 | 08:03 PM
TRAXION's Avatar
Danny,
Without a doubt ... hands down ... the Vigilante is THE best modification I have ever done to my car. Ever. It increased the driveability of my car as well as the performance. After I did heads and cam (oh so long ago) by car was a dog. I lost a lot of torque. I went from 13.6's @ 102mph to 13.0's @ 108mph. BUT, my 60ft was slower ... proving the fact I lost torque. I did the vigilante and WOW ... the most awesome mod I have ever done.
Tim
Old Oct 16, 2003 | 09:25 PM
rockind78's Avatar
I thought I remember Ed liking his??? I was really considering one for the Chevelle, but I can't seem to find 'em for the 200R4. I guess they don't make 'em.
Old Oct 17, 2003 | 10:52 AM
BuckeyeROC's Avatar
They list the 2004R here: http://www.converter.com/vigilante.htm
Old Oct 17, 2003 | 05:19 PM
David 91RS/Z28's Avatar
Buckeye....I think I mentioned this before there is no such thing as a Vigilante 2200?? The lowest stall is around a 2400. If you can look up the part # from when you purchased the converter I can tell you exactly which stall you have. I would bet you have a #259315 or #259415 which will flash approximately 2500-2600 with your setup.
Old Oct 17, 2003 | 05:58 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Originally posted by TRAXION
Danny,
Tim
I know I'm not quoting the originator of this thread and it's not even on topic but... I have to say TRAXION is right on with this opinion of a PI Vigilante. My best buddy, who is also a 15 year tranny builder, had never seen a high stall converter he liked. He's rebuilt many trannys because of cheap high stall converters that came apart and took the tranny with it.
Well, he'd never driven anything with a VERY expensive converter like the VIG before either. He drove my truck with a 383 Stealth Ram, CC306 cam, 700r4 and he didn't believe it was 2800-3200 stall until he punched the throttle. When it hit he was amazed. But still, driving it around town is an absolute pleasure. It's not all loose and slipping. It almost seems like a normal converter. It also made tuning it somewhat easier and took some of the harsh shift out of it during normal driving.
Anyway, it's a upgrade I fretted over for months. But instead of buying two or three cheap high stall converters I just bought what was recommended by these guys and for about 5k miles and many hard passes the tranny fluid is still nice and pink with not a hint of burning or overheating. (I do ran a fairly large tranny cooler and have my fans running at 184on, 176off)
Oh, and on the drag radials, I use 275/60/15 BFG DR and do a mild burnout with a couple of short dry hops. In a 4000# pickup with stock rear suspension I get a 1.88 60' time.
I DO wish the stall was a little higher now also but since I bought it second hand/but new, the one free restall isn't an option.
Old Oct 17, 2003 | 09:41 PM
rockind78's Avatar
Well thank you!!! I do appreciate your taking the time to look. I checked out that first link and didn't see anything. Its nice to know the option is there. You guys seem to reallly dig their products.
fasteddi
Sep 10, 2015 09:32 AM
IROCZ1989
Sep 4, 2015 11:54 AM
Jer82Z28
Oct 22, 2002 12:00 AM
Monkie
Theoretical and Street Racing
38
Oct 17, 2002 11:01 PM
90Iroc-Zee
Jun 21, 2002 03:05 PM
