KNOCK counts
Old Oct 17, 2003 | 05:36 AM
CL2's Avatar
CL2
KNOCK counts
I am using Diacom to scan my engine. I have a 92 speed density setup. The engine is a 305 with T5. Minor mods- Headers,true dual exhaust,21lb acccel injectors,air foil,K&N.
My problem is that I am getting knock counts constantly. The scan tools shows the counter running up to 256 and then starting over. When I drive the car it will pull out timming and this will kill my power. I have replaced the knock sensor. I have even unpluged the knock sensor and it was still showing knock counts. I did get an ESC error when the knock sensor was disconnected. I have also tried a new ECM. The only thing I can think of is that the Memcal's KS aera is bad.
Any thoughts
Old Oct 27, 2003 | 01:50 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Re: KNOCK counts
Any thoughts
I'd first check the initial timing setting.
If you suspect it's false knock, you can change to a different ESC module which is less sensitive.
The P/N is 16038331
Hope this helps.
Jake
Old Oct 28, 2003 | 03:32 AM
IDOXLR8's Avatar
I have been having the same problem changed MEM-cal, knock sensor ecm and traced all wireing and nothing fixed it took a 1.5 hour road trip to vegas and found the problem when I got home at the expense of a 5K mile stroker come to find out CYL 4 accel 30 Lb injector had been pluged most of the way. I would recomend checking the injectors I would if I had a second chance.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
spartanreaper
Sep 25, 2015 07:22 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
