Edelbrock Intake
Old Oct 17, 2003 | 04:06 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Edelbrock Intake
Has anyone tried the Edelbrock TPI intake manifold and, if so, do they think they are worth the money? I am considering purchasing one and was wondering.
Thanks.
Old Oct 17, 2003 | 04:21 PM
jeffsbluez's Avatar
Car: 91 z28
Need some work out of the box to flow as good, as it should out of the box. I bought a ACCEL lower and was very pleased . Much more money than the edelbrock. DO NOT BUY THE TPIS ONE. IT IS AN OVER PRICED EDELBROCK ONE.
Old Oct 17, 2003 | 04:27 PM
Morley's Avatar
Actually TPIS's Big Mouth intake is a worked over Accel intake.
Old Oct 17, 2003 | 06:06 PM
btcamaro's Avatar
Car: 91 Camaro
Engine: 383
I have the edelbrock intake and runners and they did need some port work done to them out of the box but not a big deal considering how much less $$$ they are than the accell and tpis ones. I am considering going with a mini ram on my engine if you are interested i would sell the intake and runners for $400.00
Old Oct 17, 2003 | 06:25 PM
Guest
Guest
Posts: n/a
No, its an Edelcrock intake.
Old Oct 17, 2003 | 10:58 PM
Morley's Avatar
do a search on here.
Old Oct 17, 2003 | 11:52 PM
Jed's Avatar
Jed
Car: 89 Formula 350
Engine: 360 / HSR
Did someone say search?
Straight from the FAQ section:
Q: Are the Accel, Edelbrock and TPIS TPI intake base the same?
A: The Edelbrock and TPIS TPI intake base are both made by Edelbrock. TPIS does go one step further and port matches all the entries and exits on the manifold and the others do not.
Accell makes their own TPI intake base.
All three TPI intake bases are pretty much the same, and you would be hard pressed to tell the difference in performance between the three.
Old Oct 18, 2003 | 05:21 AM
Guest
Guest
Posts: n/a
You first.
Old Oct 18, 2003 | 10:11 AM
Morley's Avatar
You first.
Don't have to, I've seen them. The early offerings from TPIS still had the Accel logo on the manifolds.
Old Oct 18, 2003 | 11:14 AM
Guest
Guest
Posts: n/a
And if you call up TPIS today and order one, it will be a ported Edelcrock manifold. Dont believe me? Order one and find out. I've seen enough of them, its not an Accel base they are selling.
Old Oct 18, 2003 | 01:24 PM
What sort of work should I do to the Edelbrock intake manifold, if I was to buy one?
Thanks.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Rally Smith
Sep 14, 2015 06:59 PM
toronto formula
Sep 10, 2015 07:31 AM
john204481
Sep 7, 2015 03:22 PM
