cold start injector
Old Oct 18, 2003 | 08:09 PM
rspeed7racer's Avatar
Car: 79 chevy malibu w/ tpi
Transmission: th350
cold start injector
how does the cold start injector work?? what is the sequence of all injectors including the cold start while cranking??
Old Oct 22, 2003 | 01:38 PM
Transmission: th350
csi
fine dont help me then
Old Oct 22, 2003 | 03:06 PM
rezinn's Avatar
There is a coolant temp sensor in the front of the intake manifold (square shape connector) that activates the cold start injector when starting under a certain temperature. While cranking, the distributor lets the computer know that it's spinning and firing, and the computer fires off all the injectors at the same time. In 88+ the ninth injector was replaced with fuel enrichment programmed into the chip.
Are you having some problems or just want to know?
Old Oct 22, 2003 | 06:10 PM
Transmission: th350
cold start injector
im having a major problem!! i just did a tpi swap into my 79 malibu (350) and it starts cold but will not start when its hot . i have checked the fuel psi , ignition timing, and just about everything else ive come to the conclusion its from a slow cranking speed(if that would cause the problem) os the injectors arent pulsing when its hot . im really stuck any suggestions?
Old Oct 22, 2003 | 06:13 PM
rezinn's Avatar
Does it start when you give it starting fluid while hot?
Old Oct 22, 2003 | 06:34 PM
Transmission: th350
csi
yes then it keeps running till i turn it off like it just needs that little kick in the butt
Old Oct 23, 2003 | 12:56 AM
rezinn's Avatar
Obviously a fuel problem then. Not a csi issue, though. Got access to prom burning equipment?
Old Oct 23, 2003 | 04:31 PM
Transmission: th350
csi
yeah my friend can do a little prom burning . i think my injectors arent getting enough juice to pulse during cranking because of my old huge starter. what can i do with the prom? im using gmecmedit
Old Oct 23, 2003 | 08:57 PM
rezinn's Avatar
Look at the cranking fuel tables. You'll find that the computer needs a certain amount of reference pulses from the distributor before it fires the injectors. If you make them fire earlier it may fix your problem.
Old Oct 24, 2003 | 06:53 AM
clippjr8's Avatar
i had the same problem with my 89 iroc. it does not have the cold start injector so that was not the problem for me. i spent two years chasing down the problem changing sensors and injectors and prom tuning. i was workin under the hood one morning and stumbled across a single red wire near the firewall on the passanger side that was disconnected. it had sort of a snap cap on it so i looked around that area and tucked under the wiring harness was the other end of it. snap it together and you guessed it, no more problem. i think it was some sort of ground for the computer and injector circuit. maybe this is your problem. just thought i would share my experience with you. hope this helps. good luck
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
