Heads and New Base????
Old Oct 19, 2003 | 10:16 PM
Scott57350's Avatar
Car: 1991 Z28
Engine: 355 TPI
I was wondering if anyone could tell me if a new base such as edelbrock or any other company would fit to Dart Pro 1 Aluminum heads?
Old Oct 20, 2003 | 08:58 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
As long as the port sizes on those Darts isn't so huge that it requires a 1206 gasket, any stock or aftermarket base will bolt up (vortec stuff not withstanding). You just need to make sure you get the early style base, because the later ones will have the center bolt holes at the wrong angle.
Old Oct 20, 2003 | 12:40 PM
Scott57350's Avatar
Car: 1991 Z28
Engine: 355 TPI
I wanna saay the darts are 64cc and 200cc. What do you mean by the older style ones? I want a new one that is larger then stock.
Old Oct 20, 2003 | 02:58 PM
Jim85IROC's Avatar
in 87 the bolt angle for the center 4 intake manifold bolts changed. I doubt the Darts use the new angle, so you need an early style TPI manifold, which everybody produces anyway.
But if the Darts are only 200cc, they should mate pretty well to a 1204 or 1205 with minimal work, so you should be able to use any aftermarket TPI base... TPIS, Edelbrock, AS&M, Accel, etc..
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Keith5
Aug 27, 2015 04:37 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
89-S-dime
Aug 12, 2015 11:57 AM
