Just got done with motor swap from 305 TPI to 350 HSR, ??? within
Old Oct 20, 2003 | 01:39 PM
86WS6_T/A's Avatar
Car: 2003 Mach 1
Hey guys, just got my swap all buttoned up.
First things first. Swap wasn't hard at all. The only problems I encountered were hood clearance and swap from large cap HEI to remote coil HEI dizzy.
First question. Right now I'm running the stock 305 chip until I can make it to Tomball so 1bad91Z can burn me a new one. What should I set my fuel pressure at so I can quit puffing black smoke when I get into the throttle? I have FMS SVO 24# injectors that replaced the stock 19#. I originally had it set at 43 psi but I bumped it down to 40 psi but haven't driven the car yet. I also just hooked my o2 sensor back up. Will it make that big of a diff.?
Second, I'm having some irradic idling problems. Sometimes, it will idle at 700 rpm in gear and 1000 in park, sometimes at 1100 rpm in gear and 1500 in park. I know I prob need to go back and reset the IAC and TPS but why would it switch between the 2?
Third, i'm having a problem that I had before the swap. When slowing down approaching a stop sign, light, etc, the car will idle, then stall out for a split second but never actually fully stall, just a sharp drop in rpms. Usually does it 2-3 times then will go back to normal. No idea on this one...
Thanks for all the help,
Herb
Old Oct 20, 2003 | 02:33 PM
Merlin7734's Avatar
Erratic Idle
I had similar problems with my idle and it turned out to be vacuum hoses. After clamping those all down nicely All of the inconsistancy went away (minus the miss b/c I've yet to change the sparkplugs (kcuf you edlebrock headers)).
BlueIroc-Z
Jun 9, 2019 03:22 AM
1nastygta
Oct 28, 2015 08:51 PM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
