o2 sensor causing surging idle/dying in gear?
Old Oct 22, 2003 | 12:02 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
86 Iroc Z. SD 355 Superram. Surging idle, dies when you put it in gera. etc. It idles great until it goes into closed loop. Any suggestions? I have replaced fuel filter, adjusted IAC, TPS, spark is steady, fp is steady, seams to have no vacuum leaks.
Chris
Old Oct 22, 2003 | 01:50 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
sounds like it could be the o2. I'd throw a scan tool or a volt meter on it to be sure.
Old Oct 22, 2003 | 02:45 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
scan tool is showing that it is working, stays between 126-132 even at idle(if you can call it that)
Chris
Old Oct 22, 2003 | 03:29 PM
no1kicker's Avatar
Car: 1991 Trans Am
Engine: 5.3L
Transmission: auto
From what I've read, if the car is sluggish it is most likely ignition, fuel, or a sensor. Looks like you've ruled everything else out. I had the same problem last week and the O2 did the trick.
Old Oct 22, 2003 | 08:18 PM
Jim85IROC's Avatar
Chris
What stays at 126-132? Your oxygen sensor voltage should constantly fluctuate above and below .5 volts.
Old Oct 23, 2003 | 01:15 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
UPDATE
Sorry, was referring to the o2 block learn.
Undid O2, still doing the same thing. New(cleaned plugs) same thing. So here is a new list of things I have ruled out
-plugs(cleaned)
-tps(adjusted and working correctly)
-iac(adjusted and working correctly
-fuel filter(replaced)
-fuel pressure(verified)
-o2 sensor(unplugged/same symptoms)
-vacuum leaks(none found or heard)
Next I guess I will have to pull the superram after I try a pressurized fuel injector cleaner(professional grade). Any more suggestions??
Chris
Old Oct 23, 2003 | 10:29 PM
Steve89GTA's Avatar
Auto? Sounds like a torq converter not unlocking or locking prematurely. I'd suspect the tranny. Next time it does it, quickly put the car in neutral. If it smoothes out, the tranny is probably at fault. Makes sense to me.
Old Oct 24, 2003 | 10:55 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
It also surges in nuetral and we have a lot of gas in the plenum. We think it may be a suspect injector. Off comes the superram. Anymore suggestions, opinions.
Chris
Old Oct 24, 2003 | 11:18 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
possible faulty collent sensor . Had a cracked one on a 88 TBI motor in a truck ...... ran really rich( high gas smell ) , stumbled after a while of driveing ........
something else to check
Old Oct 24, 2003 | 05:07 PM
Jim85IROC's Avatar
so wait... you unhooked the oxygen sensor and nothing changed. It sounds like it could still be an oxygen sensor issue to me. If your oxygen sensor is FUBAR, unplugging it won't cause the condition to change.
bamaboy0323
Sep 3, 2015 06:07 AM
jbd1969
Aug 17, 2015 07:06 PM
mizz0313
Aug 12, 2015 06:45 AM
