Tpi Air Intake
Old Oct 27, 2003 | 01:23 AM
white88formula's Avatar
Car: 2000 Chevy Tahoe
Engine: 5.3 v-8
Tpi Air Intake
i was curious would the dual air intake off of the iroc camaro's with 350 tpi, ya know the one with the 2 filters in the nose of the car, fit on a 88 firebird formula??? or is there not enough clearance for it to fit?? just curious
drew
Old Oct 27, 2003 | 01:27 AM
bigals87z28's Avatar
Car: Check The Sig
nope, thats why they created a different intake for the brids. the hood slopes down to much.
Old Oct 27, 2003 | 01:29 AM
Engine: 5.3 v-8
what could i do without spending the big bucks to make the intake better??? dont have tons of money just bought a t56..YAY
Old Oct 27, 2003 | 01:32 AM
Car: Check The Sig
not to sound like a broken record, but try to do a search cause there are a lot of threads about cold air intakes made for birds here. Ill post a few later. And welcome to the site!
Old Oct 27, 2003 | 09:58 AM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
Dont have money yet doing a T-56 swap?? Anyways, theres tons of free mods u can do on the TPI to help it out, not just CAI. It'l help getta up and moving a little quicker. Just do a search.
Old Oct 27, 2003 | 10:03 AM
Car: Check The Sig
Here are some threads about CAI's.
https://www.thirdgen.org/techbb2/sea...by=&sortorder=
Old Oct 28, 2003 | 10:49 PM
johnh's Avatar
Car: 2004 GTP CompG
Engine: L32 SC
I just ripped out the canister thingy and used a small piece of 45* pvc and put a huge cone filter on the end of the stock tubing.
I then fabricated a plastic heat shield and it keeps the heat from the engine and radiator from the cone filter..this is a noticable difference on both the top end and throttle response.
The biggest cost is the filter $50. The plastic heat shield is Polyproplyene 5 PP 5..used in some garbage cans ($3.99 office store). This is the same material used to make the case for car batteries.. has great chem resistance and is heat resistant with 180* continous service temp...
It doesn't look too bad and it was cheap...eventually I wanna replace the stock tubing with some aluminum..but my mock ups kept hitting the hood...
HTH
Old Oct 29, 2003 | 11:54 AM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
now here's a question....would the camaro tpi box fit on a firebird with a Ram-Air 1 hood (ASCD) ? Would it provide enough clearance?
1992 Trans Am
May 10, 2023 07:19 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
bryan623
Aug 10, 2015 11:33 AM
