IS this coming from my Intake Temp Sensor?
Old Oct 27, 2003 | 01:18 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Is this wiring harness coming from my intake air temp sensor? If it's not....does anyone know where the wires from the intake air temp sensor are? Thanks
Old Oct 27, 2003 | 01:38 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
umm... shoudnt be.... the intake air temp sensor tends to be attached to the air box up front......
athough you cant really see much but a plug from that pic.
Old Oct 27, 2003 | 02:59 PM
Engine: 5.7
are you talking about for the MAF set up? On the MAP set up....there is no plug that goes into the air box...
Old Oct 27, 2003 | 03:01 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
im just talking every GM FI setup ive ever seen or messed with...
they all get the air temp from the air box...
that plug isnt even pointing towards the air at all...
Old Oct 27, 2003 | 03:15 PM
87350IROC's Avatar
Car: 87' IROC
TPI doesn't have a sensor in the air box. Yes, that looks like the IAT wire.
Old Oct 27, 2003 | 03:38 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Been a year or two since I had my intake off, but IIRC, my MAT is located in my plenum, as far as I know, SD cars are the same way.
Only MAT/IAT I know in the inlet tube are the "relocated" variety.
I think only the V6's had the IAT located in the air inlet tube stock.
IAT and MAT are pretty much the same beast...Manifold Air Temp sensor, and Intake Air Temp sensor...but for "tTech-Speak", probably not.
Old Oct 27, 2003 | 06:05 PM
92RSZ's Avatar
Car: 91 Z-28
Engine: 420 sbc
Axle/Gears: 12 bolt/4.10 gears
yes, thats the pigtail connector that connects the iat sensor to the wire harness, i relocated mine to the airbox and had to plug the extension into that.
Old Oct 27, 2003 | 11:17 PM
Engine: 5.7
I've been thinking about doing that too
Old Oct 27, 2003 | 11:24 PM
Engine: 5.7
do you happen to know which wire is the "hot" wire? There is a brown and a black wire....I was thinking that the brown was hot
Old Oct 28, 2003 | 01:28 AM
Morley's Avatar
I thnk your "brown" wire is actually pink, time and heat changed its color. I know my wires for MAT are pink and black, and the pink should be hot.
Old Oct 5, 2007 | 08:32 AM
svroom's Avatar
Re: IS this coming from my Intake Temp Sensor?
I am having trouble getting spark on an 88 305 TPI TransAm. When I went to connect the Intake Air Temp sensor, the only thing I found that fit was on the coil. Now that doesn't sound right, I know but there is a two section connector and this pigtail from the IAT fit one half. I am speculating that is this picture shows the IAT connection I must have it wrong. Can you help?
Skip
Old Oct 25, 2007 | 07:10 PM
svroom's Avatar
The IAT is located under the TPI plenum about four inches from the back and wires to a conenctor in the harness adjacent to the the back of the plenum.
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
TheExaminer
Aug 26, 2015 04:59 PM
