52mm TB and SR??
Car: 91 Z-28
Engine: 420 sbc
Axle/Gears: 12 bolt/4.10 gears
52mm will outflow the motor until you are upwards of 400 cubes, a 58mm on a 350 will slow down air velocity and hurt low and midrange power, ie bad street manners.
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
You can run whatever TB you want actually. Before I got the proper mounting bolts for my TPIS 58mm TB I was still running the stock TB on my SuperRam. I wouldn't buy in to the "58mm is too much for under 400CI" hype because nobody here has actually compared them on a highly modded motor.
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
I'm getting the 219/219 cam and I have AFR 180's on the way. I just wanted to make sure my TB would bolt up no problem. I read a post somewhere that said you NEEDED a 58mm TB.
Thank's for clearing that up for me everyone.
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
Car: 91 Z-28
Engine: 420 sbc
sure i can back it up. call tpis like i did and ask them. they will say the same thing that i just did. they told me, "If you dont plan on building a 406, a 52mm is plenty. A 58mm on a 350 is overkill. You will lose bottom end." Those are exact words from people who have worn out more tuned ports than i will ever see. And companies like to sell things, so why didnt they bs me into buying a $200 dollar extra throttle body. because its not necessary.
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Nobody on here has done the testing to 'prove' their point so now it is just a disagreement
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
Such hostility, but there is good news. I just saved a bunch of money on my car insurance by switching to Geico.
Car: 91 Z28
Engine: Forged 383
Joe
Car: 91 Z-28
Engine: 420 sbc
thats cool man. i just posted because i wanted to let people know that if they want to save a few bucks, a 58mm may not be necessary unless youre making big power. i dont think a 58mm would hurt much either. nobody races at part throttle, so that lost bottom end is only going to show up during street driving if at all. If you got a car that already runs 12s, then the loss is probably negligable. if you got the money and plan on building a monster, then a 58mm couldnt hurt.
Car: 91Z
Yes, I agree with Camaro Joe. If I had a stock TB I would go with a 58mm, I feel that I would have enough airflow in the 355 to only benifit from it!!
Fred SS
Oct 12, 2015 11:27 AM
Magman
Sep 14, 2015 01:30 AM
vortech305
Aftermarket Product Review
May 19, 2001 03:38 PM
86TpiTransAm
Jan 31, 2001 10:19 PM
