what to do about alternator brackets when installing a TPI on a carb'd motor
Old Oct 29, 2003 | 05:37 PM
beater74's Avatar
Car: 1974 k5 blazer
Transmission: th350
i am going to install an 86 TPI (converted to MAP) on my formerly carb'd 350. The problem i have run into is the stock alternator bracket will not work with the TPI manifold. the stock alternator bracket that is on the passenger side bolts to the water pump and the termostat housing on the carb manifold. i have though about modifing the stock bracket to make it workbut i'm not sure if i will have any clearance issues with the throttle body.
Do you fellas have and ideas or know of any aftermarket brackets that will keep my alternator on the passenger side?
Old Nov 6, 2003 | 07:03 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Have you tried a salvage yard for a wrecked car that may have what you need?
Jake
Old Nov 6, 2003 | 09:43 PM
Deik's Avatar
Car: 87Z28,90RS,85-2.8to305
Engine: 350TPI,350carb,305carb
Transmission: 700R4,T-5,700R4
Hit the junk yards f0r a set of alum brackets that will bolt to the front of your engine PS,AC ALT,smog it all bolts up and should be able to get it pretty cheap gave 20 bucks for mine works great and changed over to serpentine belt hope this helps.Mine is off 90rs.
Old Nov 8, 2003 | 11:19 PM
onebinky's Avatar
Just pick up the TPI bracket for the V-belt setup. The lower bolts attach to the waterpump and head like your current setup does, but the uppermost bracket bolt attaches to the front runner bolt on the passenger side.
Matt
Old Nov 9, 2003 | 06:44 PM
beater74's Avatar
Car: 1974 k5 blazer
Transmission: th350
Matt
thanks i call around and see if i can find a used one.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
86IROC112
Aug 17, 2015 02:00 PM
drathaar907
Aug 6, 2015 04:20 PM
