LPe 219 and Pro topline heads???
Old Nov 1, 2003 | 02:37 PM
1990irocz28's Avatar
Car: 1990 iroc 5.7
This is what i have right now:
-Accel/Lingenfelter Superram intake manifold
-LPE 219 camshaft
I need to know what is a good intake runner size for this combo.
180cc,200cc, 220cc, or 235cc?
I dont know anything about cylinder heads. Is Pro Topline Pro Action a good brand? I just want to bolt these on and go.
Old Nov 1, 2003 | 08:56 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'm guessing the 200cc heads would be good for you...for comparison, the LPE219/SR/AFR 195 combo is a decent 11sec setup.
Old Nov 1, 2003 | 08:58 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Ya know, what I mentioned may be woth 383's...so the combo w/AFR's should still be a solid 12sec runner in a 350.
Old Nov 1, 2003 | 09:57 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
out of those, on a 350, the 200 is the best choice.
Old Nov 1, 2003 | 10:00 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
Yep, it is. With the potential for 11's as well.
Old Nov 1, 2003 | 10:04 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Sure...quote my misspellings..
Old Nov 3, 2003 | 02:49 AM
Car: 1990 iroc 5.7
What chamber size?? 50cc,64cc or 72cc? Whats the difference between the three sizes? thanks for your help
Old Nov 3, 2003 | 06:52 AM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
Re: LPe 219 and Pro topline heads???
-LPE 219 camshaft
If you run a 350 I like the 180's, if you run a 383 I like something around 195cc (hint..AFR), and if you run a 400 with that cam and intake I'd go with something around 200cc.
With most flat top pistons, 64cc chambers would probably work best. Most pistons like this chamber size. I'd go anywhere from 10 to 1 to 11:1 compression with that setup. It's a real "street friendly" setup, which is cool.
Old Nov 3, 2003 | 05:25 PM
Rippin92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: GM T56
So a SuperRam, LPE 219 Cam and AFR 190/5's will run low 12's? Holy crap!
-Rippin
Old Nov 9, 2003 | 10:47 AM
Corvette0096's Avatar
I ran a 12.300@113 with the 219 and a SR with 180cc runners Protoplines. 350Cid
Old Nov 9, 2003 | 08:11 PM
Rippin92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
In a vette?
Old Nov 9, 2003 | 08:36 PM
Originally posted by Rippin92RS
In a vette?
Yep..85 vette auto tranny.
Old Nov 10, 2003 | 08:31 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
-LPE 219 camshaft
Since you're running port injection you could use 220cc or larger intake ports. 64cc is a good chamber size for 350/383.
Old Nov 10, 2003 | 08:41 AM
Re: Re: LPe 219 and Pro topline heads???
I am building a 383 right now and the 180cc are going on. They Out flow my Super ram in stock form as is. They flow 260@500. These are actual # for my heads. Yes I had them flow tested. I have read that there are some issue with push rods alighnment with the bigger cc heads. Hitting the intake runner housings. Buddy went with a 200cc on the same intake and cam and he never mentioned any problem with clearances. I like the Idea of a smaller cc runner for the bottem end grunt.
Reddeath210
Oct 6, 2015 08:20 AM
Magman
Sep 12, 2015 10:43 PM
Ducati900ss
Sep 2, 2015 09:05 AM
gixxer92
Sep 1, 2015 04:32 PM
