What are the ebst heads for my setup?
Old Nov 5, 2003 | 08:09 AM
IceBlue91z28's Avatar
Car: 1991 Camaro Z28
Transmission: Built 700r4
I have a 1991 z28 with a new Jasper L98. Im not ecatcly sure which jasper it is but it has some kind of cam in it. I have an ed wright stage 2 dast chip, 25lb/hr ls1 injectors, headman headers, 3 inch flowmaster exhaust, and a pretty much stock tpi setup. This engine has around 300 hp or more as it sits(i believe the jasper has 300 when I got it so the extra stuff I did added a little more power). I was wondering what are the best heads for a TPI setup like mine. Maybe a cam too. Thanks.
Old Nov 5, 2003 | 12:39 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
What is your price range, what are your cam specs? The question is just too general to get a specific answer.
Old Nov 9, 2003 | 09:32 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Really you just need to get heads that you can afford, and then think about a cam, if you feel the need to get a new one or not. It is not really practical to pick a set of heads based on cam specs. You usually pick a cam based on cylinder head flow, not vice versa. Basically what is your price range?
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
