Vette vs. fbody shortblock differences
Old Nov 5, 2003 | 05:09 PM
mhaskell's Avatar
Are there any differences between a 1987 vette L-98 shortblock, and a f-body Shortblock of any year? Every part should be interchangeable right?
Old Nov 5, 2003 | 06:54 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
I think the only difference in the shortblock is the cam. someone correct me if Im wrong.....
Old Nov 5, 2003 | 07:15 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
not sure if the Vette got 4 bolt mains, but everything will interchange
Old Nov 5, 2003 | 07:26 PM
87irocz350's Avatar
Car: 87 Iroc
Transmission: T-5 3.42's
The Vette L98 got the 4 bolt main. Fbody got 2 bolt. Vette got the alunimum head. Fbody cast. Other small differances. Every part should be able to swap.
Old Nov 5, 2003 | 08:20 PM
91dubZ28's Avatar
Car: 1991 Z28
Transmission: WCT-5
did they do the 4bolt in 87 my buddies 86block was a 2bolt
Old Nov 5, 2003 | 09:04 PM
87350IROC's Avatar
Car: 87' IROC
I do believe all L98s are 2 bolts.
Old Nov 5, 2003 | 09:10 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
correct
a 4 bolt L98 was never made
your thinking of LT1's
vette and fbody LT1s were 4 bolt
while impala LT1's were 2 bolt
Old Nov 5, 2003 | 09:15 PM
Dave Y's Avatar
Engine: 4.3L V6
Originally posted by 1991tealRSt-topGuy
correct
nope, only vette LT1's were 4 bolts from the factory, replacement blocks could be 4 bolt IIRC, The LT4's were 4 bolts also
Old Nov 5, 2003 | 11:23 PM
mhaskell's Avatar
So the cam and pistons are the same? The heads are the only reason for a higher compression ratio correct? Any idea on what size cam is in the block?
Old Nov 5, 2003 | 11:24 PM
Gold86Vette's Avatar
Car: 86 Corvette
Engine: 420 Cube SB
My original motor in my 86 vette with aluminum heads was only a 2 bolt with a 1 piece rear main seal.
Old Nov 6, 2003 | 05:47 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
As mentioned above, ALL L98s were 2 bolt whether in a 85-91 Vette or 87-92 F-body.
Old Nov 6, 2003 | 11:05 PM
Car: 86 Corvette
Engine: 420 Cube SB
Doesn't really matter 2 bolt or 4 bolt anyways. How many people can break a stock chevy 2 bolt? My 86 stock bottom end went 12.363 @ 112.04 and ran strong for over 5 years drag racing it every other weekend and about 25,000 really hard street miles. I never broke anything on the bottom. That car was driven to the track everytime (85 miles each way) and never stranded me. The only reason I retired it was that the valve guides wore out. My new motor is a 400 bored and stroked to 420 cu. and guess what - its a 2 bolt!!! I have all the faith in the world with chevy bottom ends as I have never ever broke a crank or spun bearings. Ask a ford guy about their small blocks (very prone to splitting right down the center). Thats why chevys rule and always will.
Old Nov 7, 2003 | 06:58 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
I had a 90 vette engine, it's cam was the same as a ZZ-4, not sure if it was original or not, it was a 2 bolt main engine, it also had a windage tray, the harmonic balncer was different (not quite as thick as a 89 TBI 305
Old Nov 10, 2003 | 01:43 PM
Black363IROCZ's Avatar
Car: '88 IROCZ
Engine: 363 Vortec w/Miniram
Transmission: built 700r4
Vette L98s are 4 bolts, the motor is exactly like a ZZ4. so anyone who wasted the $3500+ for a ZZ4 could've just bought a corvette L98 from a junkyard for like $800 and spent the difference modifying it.
Old Nov 10, 2003 | 02:45 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
How can you guys even compare a vette bottom end to a ZZ4?
ZZ4's have...
Forged Crank
Forged PM Connecting Rods
4-Bolt block
Vette's have the same parts as the L98 ....
Cast Crank
Cast Rods
2-Bolt
They are completely different.
Tim
Old Nov 10, 2003 | 02:59 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
As tim already pointed out, besides both displacing 350ci, the vette and ZZ4 share nothing in common.
And, also as already mentioned in this thread, Corvettes DID NOT get 4 bolt mains. Thats an old wives tale that has been proven false by the legions of vette owners who have had their engines apart over the years.
Old Nov 10, 2003 | 03:10 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
My vortec block is a 4 bolt.
Old Nov 10, 2003 | 03:54 PM
Rock90rs's Avatar
Car: 92 RS/90' vette
Engine: Heads/cam/miniram/blah blah blah..
Transmission: T5/700!
Axle/Gears: 3.08
The only thing they do share is the 113 head CASTING, but the ZZ4 has an LT4 valvetrain.
#1 I will also second the fact that ALL L98's are 2 bolt main.
#2 The cam profile may have been slightly different in the vette depending on the year model. If it was, it wasnt much.
#3 The vette does have a higher comp. ratio, because the 113 D-port aluminum L98 heads have 58cc chambers.
#4 I dont see any reason why they would not be interchangable.
Old Nov 10, 2003 | 04:04 PM
Rock90rs's Avatar
Axle/Gears: 3.08
Nope, not the original cam
Old Nov 10, 2003 | 05:20 PM
TRAXION's Avatar
My stock L98 is an 8 cylinder ... free post!
Tim
Old Nov 10, 2003 | 09:47 PM
my bad, about the LT1, you are correct
i was thinking that the vette and f-body got aluminum heads
while the impala receieved iron
me
Old Nov 13, 2003 | 03:41 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
me
Vettes got aluminum heads in mid-year 1986. Mine is an early 86 Vette and had iron heads.
It is a 2 bolt block with a one piece rear main seal; neutral damper and weight on flex-plate.
Jake
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
Nick McCardle
Sep 10, 2015 08:36 PM
scottmoyer
Sep 7, 2015 07:06 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
