oil pressure flutter??
Old Nov 6, 2003 | 11:20 PM
grndmasnightmar
Guest
Posts: n/a
hey my altenator is steady but my tach fluctuates at a stop light back and forth from 600to700rpms and the oil pressure keeps bumping like 40 to 50 40404040 then 50 again. this doesnt always happen, usuallt the preesure is at 30 stopped and 60 driving. i have 10w30 mobil oil a slighty leaking pan gasket and the bottom is dented. any ideas..
Old Nov 7, 2003 | 07:00 AM
bigals87z28's Avatar
Car: Check The Sig
umm id fix the pan asap, but what your describing doesnt sound all to bad... your getting fuel pressure which is good... well at least at idle. When you are driving near or at WOT does it drop? Thats where you will have a problem.
Old Nov 7, 2003 | 12:35 PM
grndmasnightmar
Guest
Posts: n/a
no..
well the [an has been that way for like 2 yrs(is that bad and why?) the pressure though is nice and steady while driving at wot from whaat i believe its at 60 always...
Old Nov 8, 2003 | 11:08 PM
onebinky's Avatar
If the bottom of the pan is dented, it could be blocking the oil pump pickup and reducing flow to the engine. The slight leak on the oil pan wouldn't affect the oil pressure any.
The fluctuating oil pressure while stopped is more than likely a bad sending unit. It's the one on the rear bridge of the block up by the manifold. Also check out the wire on it, and make sure you have a good solid connection and the wire isn't shorting out anywhere.
Good luck,
Matt
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
db057
Aug 22, 2015 08:17 PM
