i need the specs on lb9 heads
Old Nov 19, 2003 | 11:45 AM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
hey i have aset of lb9 heads 5.0 tpi heads and i wanna to know the specs on the vavles?and cc?exc?and what are thespecs on the lo3 heads 5.0 tbi?i going to do this swap and i ned to know
Old Nov 19, 2003 | 02:03 PM
bigals87z28's Avatar
Car: Check The Sig
Um the LB9 heads are 58cc heads, 160 intake(i think?), dunno exhaust, Valves are 1.84/1.5. Dont know about the springs.
L03 heads suck and if you had a set of LB9 heads on you, i sugest porting them and swaping them on for a cheap fix.
Old Nov 19, 2003 | 04:50 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
thr LB9 heads will give ya alot over those LO3 heads, port them and give those heads some 1.94" valves w/ some new spring and you'll pick up a nice amount of ponies.
Old Nov 19, 2003 | 10:43 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
my motor has bad vavle seals the lo3 so i have a lb9 motor so i have the heads so im going to send those to rebuilt and then put them on/the lb9 heads have bigger vavles then the lo3's correct?im going to put a 355 nexy year in it so i dont want the 1.94 vavles yet but thanks for help how much power will i gain putting the lb9 heads the edelbrock performer and lt1 cam?
Old Nov 20, 2003 | 11:42 AM
Engine: peanut LB9
maybe 15hp w/ no mods to them at all. if ya do a little bit of porting, the new valves and the rebuild your looking at around 25hp
so my guess is being somewhere around 225hp w/ mos bolts too. but i'm reall only a TI guy so i'm not saying that i'm exactly right.
Old Nov 21, 2003 | 12:46 PM
Steve89GTA's Avatar
What would happen with LB9 heads fitted with 1.94 valves up top a ZZ4 block?
Old Nov 21, 2003 | 12:49 PM
Car: Check The Sig
just the putting in valves? It would give it some performance.. but with the small chamber you could get some detonation. The ZZ4 comes with aluminim vette heads with basicly everything the LB9 has, only larger intake and exhaust ports and larger intake valve.
Old Nov 22, 2003 | 04:24 AM
MarkB's Avatar
Car: 1982 T/A -1986 Z28
Engine: 383 -305
Transmission: T56-700r
the zz4 uses 58 c chambers too
erm,forgot about the iron vs aluminum thing :lala:
Old Nov 22, 2003 | 06:04 AM
Car: Check The Sig
yeah... the small chamber on the lb9 heads might not work to well for higher compression... thats why GM went with aluminum for the vette heads... I can only think...Im not sure. Sounds logical.
gta90
Sep 15, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
