Free mods.
Old Nov 21, 2003 | 11:52 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
Free mods.
Before anything I already did a search it turned up 18 pages and I only went through the first couple...anyways I have a 90Iroc lb9/auto etc. I have already done the tb bypass and cut the baffles out beneath the air filters. I have completed a full tune up except fuel filter which is sitting in the garage and will be replaced tomorrow...done cap/rotor/plugs/wires/coil etc... Are there any more free mods that I can do?
Old Nov 22, 2003 | 12:03 AM
TunedportROC's Avatar
Car: 02Z/89Roc
Engine: 346/350
Transmission: T-56/700R4
Axle/Gears: 3.42/4.10
under hood insulation
Old Nov 22, 2003 | 12:21 AM
87_TA's Avatar
Advance timing to about 8-9 degrees @ idle with ESC wire diconnected.
Assuming you are not getting knok retard - best if done with a 160 thermostat to cool cylinders more.
That will probably net biggest gain.
Old Nov 22, 2003 | 12:26 AM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
you think with a 160 stat and premium that I could bump it up a couple more degrees than that? like 10-11? Right now it is sitting at 6*
Old Nov 22, 2003 | 01:00 AM
87_TA's Avatar
Possibly but, If you get knock retard you will lose more than you gained .
Get a scanner or voltmeter and watch knock retard.
Or just watch track times.
Old Nov 22, 2003 | 01:18 AM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
How can you tell when there is knock retard?
Old Nov 22, 2003 | 06:29 AM
87_TA's Avatar
Well there are a few ways, Easiest way is with a scanner or laptop. If you have access to a laptop, Craig Moates makes awsome scanware that is free! all you have to do is build or buy a cable.
If no laptop- buy a scanner, these tools are pricless when modding a EFI car in my opinion. And they will also teach you alot.
Either of those will tell you, But like I said watch track times as well.
Fisrt try 8-9 degrees then maybe 10-11. My car ran best @ 10 degrees when stock.
Old Nov 22, 2003 | 03:22 PM
My86TransAm's Avatar
If you dont mind gettin your hands dirty you can yank off your plenum and ground off the egr blocks that are near the throttle body, also while your in there you can clean and polish the bores on the throttle body too. Since you did a full tune up, i assume you checked your IAC and TPS sensors.
Old Nov 22, 2003 | 08:59 PM
5SIZ's Avatar
Car: 1987 IROC-Z
Changing the stock timing on TPI usually doesn't do a darn bit of difference, except slow you down more due tot he knock sensor. I recommend just leaving it at 6 degrees.
Your better off fully porting the plenum, and shedding pounds.
Old Nov 23, 2003 | 03:34 AM
WishIHadAZ's Avatar
Car: 87 iroc
Engine: L98 350
how do you check knock retard with a voltometer??
Old Nov 23, 2003 | 04:05 AM
87_TA's Avatar
I got times before and after to prove it helped me alot.
Like I said watch knock retard and track times.
It also depends what prom your car came with , for instance the arap came with much more aggresive timing table because the alum heads on vettes. But there are several different for 3rd gens.
People generally try to add to much, or do so with 87 octane or higher coolant temps causing excessive knock retard.
Try 8 then maybe 10.. Watch times as I said.
Old Nov 23, 2003 | 04:46 AM
bigals87z28's Avatar
Car: Check The Sig
To test for knock, you would need to splice into the knock sensor wire. It gives off an electrical signal if it detects detonation. Just hook up a voltmeter in line with the wire.
Old Nov 23, 2003 | 10:54 AM
87_TA's Avatar
But easiest method would be to get yourself a scanner..
You will love it.
Old Nov 23, 2003 | 11:17 AM
Car: Check The Sig
it would be way easier, but not cheaper. I got lucky and got a laptop for free. If you have a lap top already, all you need is to load the software and make a cable.
Old Nov 23, 2003 | 06:08 PM
slkwilly's Avatar
Car: 87TransAm
Engine: 305tpi
got any clue how to make the cable? or a info site thats got good info for a NooB. I got the software and laptop though..thx
Old Nov 24, 2003 | 12:02 AM
HM Murdock's Avatar
Car: 1988 Formula and 1995 LT4 Z28
Engine: 305 TPI and 361 LT4
Transmission: M5 and stalled A4
I've already got an AKM cable and tunerCAT for my 95, it's OBD1 but has the II connector...Is there another cable half I can plug in? I'll check the site...
Old Nov 24, 2003 | 12:59 AM
MNformula350's Avatar
Remove your a/c and air equipment.
I noticed almost 65 more miles per tank of gas after i removed these, so i would assume it freed up a little hp.
Old Nov 24, 2003 | 07:28 AM
Car: Check The Sig
You should go into the DIY board. I know thats a big step and that board is a little scary but its in there, or you can get one off ebay like I did. 45 bucks and I got a TON of software with it on a CD.
Old Nov 24, 2003 | 05:28 PM
rhuarc31's Avatar
Car: 89 Formula 350
Engine: 409 nitrous' small block
Look in the tech articles section, theres lots of nice concise info there.
https://www.thirdgen.org/newdesign/tech/
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
TexasFormula
Sep 30, 2015 06:36 PM
FueledSoul
Sep 26, 2015 12:00 PM
