Most possible torque....355 TPI.
Old Nov 23, 2003 | 06:54 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
Building another L98 for the 'bird. Trying to build a torque monster that'll be a blast to drive (everyday) and run low 13's on the motor. How's this sound?
Heads will most likely be mildly ported 083's. Smooth out the casting marks on the intake runners, smooth out the bowl area and a little deshrouding of the chambers
Cam: still up in the air on this one. Leaning toward the LPE 211/219. Suggestions?
Intake: Stock TPI for now, ported base, plenum and knife-edged runners.
Old Nov 23, 2003 | 10:05 PM
87350IROC's Avatar
Car: 87' IROC
I don't think you will run low 13s with that combo.
Old Nov 24, 2003 | 10:24 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Why not?
Old Nov 24, 2003 | 11:31 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Change heads and go with at least a CC XR269HR-12 cam and you will have plenty of torque!
Old Nov 24, 2003 | 08:36 PM
Engine: LB9/383
Why even post that? Thanx for the help
What are the specs on the 269 cam you mentioned? I'm guessing you suggest it b/c you've dealt with it. How did it run, idle, etc..?
Old Nov 24, 2003 | 08:44 PM
smithtc's Avatar
The LPE 211 is a great choice. The 219 might be a bit much.
The 083s correctly ported should enable you to get into the 12s...traction, proper tune, and good shifting transmission permitting.
If push comes to shove, just swap the heads for a good aftermarket set.
Old Nov 24, 2003 | 10:36 PM
87350IROC's Avatar
Car: 87' IROC
Originally posted by NastyL98_T/A
Why even post that?
Because you asked. Why don't I think you will net low 13's? Because in my opinion you need to heavily port the heads and or go with a bigger cam to get low 13s, i think you're at mid 13's with that setup. You also didn't say if you have headers, exhaust, traction mods, prom burn, so i assume you don't. You asked a question, and i gave you my opinion, thats all.
JP
Old Nov 25, 2003 | 07:34 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Why not use the aluminum L98 heads that are on the car now? Or is this for the 2nd gen?
Old Nov 25, 2003 | 10:13 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
specs of xr269 cam:
.495 / .503
218/224 @.050
112 LSA
108 ICA
Old Nov 25, 2003 | 03:42 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Here's a combo that got my 87 to go 13.1 @ 101 at the 01 Power Tour at Maple Grove. World Torquer SR heads, Lunati 218/224, .489/.502 lift roller cam Accel Super Ram, 700R4, 3.73 gears, 85 Vette converter. I am sure you could duplicate the World heads performance with a good port job.
Old Nov 26, 2003 | 07:56 AM
Engine: LB9/383
The aluminum heads were sold. Compression was too high on them so I got rid of 'em. Thanx for the info guys.
Old Nov 27, 2003 | 05:08 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
You'll improve the airflow of the heads the most by blending the short turn (side) radius, which necessitates removal of the valves.
Jake
Old Nov 27, 2003 | 08:04 PM
quickL98's Avatar
Car: 87 trans am GTA
Engine: tesla permanent magnet
Transmission: 93 T-56
Axle/Gears: moser 12bolt w/ 3.73
i dont think you'll have to worry about making most possible torque, a TPI will do that on its own useable horsepower would be my quest with a LTR set-up. best of luck and enjoy the ride.
Old Nov 27, 2003 | 11:24 PM
87_TA's Avatar
Might want to think about some vortec heads, car craft did a 406 build using them and made 525 ft lbs with a real small lift cam to.
single pattern 230/230 480/480.
For the price they are great torque makers , especially with LTR setup
Old Nov 28, 2003 | 06:25 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Ohhh yeah I would go with Vortecs. In fact I am (getting a gmpp 350 ho eventually)... They love stock TPI, because both are torque focused. You would need to pick up a scoggin dickey lower intake plenum, and purchase the heads. Should be around a thousand bucks alltogether. Sell off the 083 heads, port em to get more $.
xodus2002
Jul 17, 2020 09:08 AM
sheachopper
Jul 31, 2019 11:27 AM
Bradsaundry
Oct 7, 2015 04:35 PM
Camaroguy2
Sep 22, 2015 08:22 AM
RedIrocZZ
Sep 19, 2015 02:22 PM
