computer is shot. how do I replace it|?
Old Dec 4, 2003 | 12:47 PM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
what is the proper procedure step by step so I dont fry it? thnks
Old Dec 4, 2003 | 01:14 PM
AlexJH's Avatar
Engine: 5.7L V8
1st. Are you sure it's the ECM? How do you know?
Do you mean the whole ECM (silver box) or the memcal (plastic plug with some chips on it)?
Old Dec 4, 2003 | 01:18 PM
SHAGME's Avatar
Car: 1988 IROC-Z
THE whole ECM my friend owns a shop and hooked it up. its fried
Old Dec 4, 2003 | 01:37 PM
Roads88's Avatar
Car: 1988 Pontiac Trans-AM
Engine: TPI 350 (5.7L)
I would check out the tech articles. I dont thinks there is that much to it. I had mine replaced and it didn't take long at all.
A 1899 iroc? Now thats a classic.
Old Dec 4, 2003 | 03:10 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
If its already fried why are you worried? Just kiddin, if you are sure the ECU is your problem, then all you have to do is make sure the key is off, remove the trim below the 'glovebox' pocket area, take out the two bolts holding it in, and unplug the connectors. The ECU sits directly behind that pocket so it has to be pulled down to come out.
Old Dec 4, 2003 | 04:17 PM
Roads88's Avatar
on my 88, my installer used an electronic device to tell the ecm what car it was in. The ecm came out of an astro van, of all things.
I figured the chip would do that. Strange!
Old Dec 4, 2003 | 04:20 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
That car dates back to 12 BC (before chevy).
Old Dec 4, 2003 | 05:35 PM
SHAGME's Avatar
Car: 1988 IROC-Z
u funny man Ill change it. or mabey not lol.
and thnks guys but... should I unplug the Battery? and I bought a new reconditioned whatever ECM, for a 1988 350 camaro. so I just have to plug it in and it should work right? thnks I need to do it tonight to gety to work thnks. Kev.
Old Dec 4, 2003 | 08:49 PM
SHAGME's Avatar
Car: 1988 IROC-Z
ok well its running alot better now but its still not quite right. I think the TPS is bad not sure. and the plugs r a mess but its fing cold outside I get up at 5am everyday. so goodnight
Bryan F
Aug 18, 2015 02:28 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
mizz0313
Aug 12, 2015 06:45 AM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
