TPI Throttle bodys
Old Dec 7, 2003 | 02:53 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
TPI Throttle bodys
What is the difference between the 85 to 88 throttle bodys from th 89 up units.
Brian Felts
Old Dec 7, 2003 | 02:55 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Should be the same 48mm TB on all TPI's over the years.
Old Dec 7, 2003 | 02:57 PM
they list the aftermarket ones for 88 and back then 89 up.
Brian
Old Dec 7, 2003 | 03:18 PM
biggtime's Avatar
there are 2 differences.
1) the linkage
the early ones used the direct pull method
the later ones used the smoother radiused pull.
2) how the IAC pulls its air
the early Tb's used a port in the plenum directly behind the tb.
the later had a slot milled betweeen the tb blades.
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
