Are 52MM Throttle Body Air Foils Available?
Old Dec 10, 2003 | 11:55 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Does anyone know? I see them advertised for 48MM Throttle Bodys all the time.....
Old Dec 11, 2003 | 12:34 AM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
I've never seen an airfoil specifiacally for larger than stock throttle bodies. I'm pretty sure you just need to use a standard airfoil and grind some material off. I'm not sure how much but it would be very minor since most of the airfoil isn't in the way of the throttle body bores. It's not like these airfoils are presicion machined. Maybe a standard one will fit and not interfere at all. I haven't looked at mine in awhile so I'm not sure. Every aftermarket larger throttle body I've seen has an integral airfoil so I guess there's no market for a 52mm specific airfoil.
Old Dec 11, 2003 | 03:41 AM
Dr G's Avatar
Steve91Z28 L98:- Not every aftermarket throttle body has an integral air foil, though most do. See the below linked thread and scroll about 2/3 of the way down for some pics:-
What's the story on Air Foils???
https://www.thirdgen.org/techbb2/sho...=throttle+body
Old Dec 11, 2003 | 10:16 AM
Engine: 5.7
i guess myabe my BBK TB already has an ail foil built in. But....I was looking at a few pictures....like this picture here....: http://www.thirdgenresource.com/inc/...l?v=1&pid=1499
See the bottom TB.....the air foil in it is about even with the outter lip of the TB...
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
